I sail alot in Ohio lakes and in the summer we have alot pop up lighting storms. I am curious what kind of protection people are using on their boats. The mast itself it a great lighting rod but it stops at the hull and does not have any conduction to the waterline.
I am thinking of running a good size wire from the mast to the Keel in a attempt to complete the circuit path. Perhaps I can use the winch cable as the conductor to the keel itself.
Any thoughts on this? It would be great if when they made this boat there is already a conductor inbeaded in the fiberglass to the keel however I think that might be a bit of wishful thinking.
C26 lightning protection
Ron,
Check and see if you don't have a very large insulated cable running from the shroud chainplates to behind the banquettes, then down into the port and starboard stowage under the seats, and then back to under the stern berth, then terminating in a metal lug thru hull.
Mine is that way, as best as I can recall, and I just assumed it was stock.
Anybody elses like this?
Lightening
I found that taking a piece of copper and placing it underneath the mast will ground it.
Jim,
That is a great story, and probably would have helped. Lightning wants the straightest/easiest path to ground potential, and that might have done it better than the grounding cables that run to my stern. Might have vaporized the jumper cables, but they should have passed the charge away from the hull and/or the electronics.
Turns out Forespar does make a brush for mastheads - $119 at WM.
Re: Woody 54
Woody Wrote: "I found that taking a piece of copper and placing it underneath the mast will ground it."
What did you ground the copper to? Keel?
How did you obtain a metel to metal contact with the mast base? Through deck bolts?
In florida lightening is a big deal. Once while sitting in Boot key harbor in Marathon, a Watkins 27 that was moored less than 100 ft away got hit by lightning. When we woke up in the morning it was sunk!
I've used the battery cable on the shroud trick since then.
