LS-13 Battens
Posted: Thu Mar 05, 2015 8:18 am
by ronney
I am restoring an old LS-13. I have good sails, but the 3 battens are missing. Does anyone know what the original thickness and width of these boards were? :P
Posted: Mon Mar 09, 2015 2:27 am
Probably going to have to measure the pocket and then make some from thin wood..I bet those are a fun boat !
LS-13 Battens
Posted: Mon Mar 09, 2015 9:49 am
by ronney
Yes, that is what I was going to do, but didn't know if the originals were tapered. I thought about just epoxy coating pieces of a yard stick. I am just about finished with the restoration and I am excited to get her on the water!
Posted: Mon Mar 09, 2015 11:01 am
I've used a thin piece of PVC-ish molding from either Lowes Or Home Depot before - on the Coronado C15. Guessing it was about 1/8" thick and 1/2" wide.
That's the spirit - get her on the water, and you'll have to much fun to care about the exact batten ! 8)
Posted: Mon Mar 09, 2015 1:09 pm
by ronney
EmergencyExit wrote:I've used a thin piece of PVC-ish molding from either Lowes Or Home Depot before - on the Coronado C15. Guessing it was about 1/8" thick and 1/2" wide.
That's a great idea, thanks!
battens
Posted: Fri Mar 13, 2015 11:51 am
by kerryon
I have some originals that were made of wood. I'll measure and can take some pics.....I think they may even have a manufacturer printed on the (would be shocked if they were still in business!) I'll check this weekend and post the info...
Replacement battens
Posted: Fri Mar 13, 2015 4:12 pm
by Carpenter Dan
Hi ronney!
My Pirateer came without battens. I found a good replacement batten at sailrite.com (part # 103325-058-24). I'm guessing that the the LS and Pirateer used the same battens. They are 5/8" wide x 1/4" thick at the center and tapered toward both edges. Easy to cut to length. Not very expensive and quick delivery. I order new ones three years ago and a couple more last years after I shook two of them loose ( that's a story for another time). One word of caution: if the elastic in the batten pockets is deteriorated from age like mine, you should use sail repair tape to close the outer end of the pocket.
Have Fun!
Battens
Posted: Fri Mar 13, 2015 5:52 pm
by kerryon
Ronney,
There are three battens. All 1 3/8" wide, 1/8 thick tapered to 3/32 at the leading edge. 19 7/8", 16 3/4" and 12" long. Small hole in the trailing end for a small cord or strap to pull the battens out of the pocket. Not sure of the wood species. Brand is " Battencraft"
Dave
[/img]
Re: Battens
Posted: Fri Mar 13, 2015 8:48 pm
by ronney
[quote="kerryon"]Ronney,
Dave
Thanks so much Dave! :)
Re: Replacement battens
Posted: Fri Mar 13, 2015 8:56 pm
by ronney
Carpenter Dan wrote:Hi ronney!
Have Fun!
Thanks for the help!
