				c22 tiller help
				Posted: Wed Jun 06, 2007 7:45 am
				by canoeman
				can anyone tell me the best way to hold the tiller straight while doing other things on the boat while solo sailing? i have thought about 2 ropes or maybe just one with a loop or some kind of knot so i can adjust. bungee?     thanks in advance   bob
				Posted: Wed Jun 06, 2007 8:07 am
				Posted: Wed Jun 06, 2007 10:45 am
				by canoeman
				thanks alot, i will give the free, nothing a month a try this eve. there is some wind on the lake. hope its still there when i get out of work!      thanks again    bob
				good info EE!
				Posted: Wed Jun 06, 2007 11:17 am
				by Gus
				I tried the Cajun Tiller tammer, didn't really work for me. The rudder sits too low in the cockpit to use the stern cleats. I do have the Davis tiller tammer, but I'm yet to install it. I was thinking in replacing the standard nylon line with a bungee cord (easy to make small corrections) but I haven't found the right size cord to fit in the tammer.
Gus
				good info EE!
				Posted: Wed Jun 06, 2007 11:20 am
				by Gus
Gus
				Posted: Wed Jun 06, 2007 11:47 am
				Oops, I should have mentioned that I was using the system with the tiller pulled "up" instead of the normal , more horizontal position when tightening the line. In y case the knot was above the cleats. Throwing in a hitch can help too.
				Posted: Wed Jun 06, 2007 4:29 pm
				by Gus
				Well, I was thinking in doing this in order to install the davis tiller tammer. I know it came with 2 little cleats, but the installation will be ackward. So I was going to drill a couple of holes in the bulkhead of the gas locker, install a couple of brass pieces to prevent chafe in the line, and finish with a washer and a knot inside the locker. But again, I haven't done anything (and the gear keeps pilling up, tiller tammer, barlow winches, bilge pump...)
Gus
