Well Shucks
Well Shucks
Hi everyone,
It's been a long time but I'm still Chrysler Sailing dreaming. I've been working, and working and working and in my spare time I've been working some more. My Boat is still sitting on it's tailor waiting to go swimming in Puget Sound Again.
I opened it up last month and found 6 very active Wasps nests and they were not pleased to see me. I closed it all back up and decided I would wait till the weather cooled down and clean the little Pirates out and then put my boat back in order. Frankly the worst it's ever looked under my ownership. Well maybe out sailing again in late Winter early Spring.
Well back to work. It's good to have a job after not having one for a couple years.
A small container of apple cider vinegar is supposed to be a very effective repellent. Spraying it on the openings creates a barrier and they will be gone within a day.
If you don't mind dusting (Sevin-5), it will kill them over the course of a week. Wear a mask.
I have taken the Rambo approach with a can of Raid wasp killer and shop vac with an extension too. What you don't kill, you draw into the vac. It is really funny to ear the thump, thump thump of the wasps as they hit the inside of the dust collector. You are done in 20 minutes.
Our boat was left fallow for 8 years by the previous owner. We also had a wasp nest created under our entry stairs that had to be eradicated. I have tried all of the remedies.
Regardless, be safe - wear lots of protective clothing and netting around your face and neck.
We are so blessed
That sounds very promising. I will try it on Sunday after work. Thanks!
Hi Alan ! Hey, right there with you on the boat status - EE was a mess after someone left hatch open at yard and she collected quite a lot of water that sat all winter - gutted (again) and shooting for spring myself.
And with ya on the job thing too - I did that for about a year in 2004, of course it was long enough ago that I've started whining about going to work again
We have these bright orange wasps that are highly aggressive down here. You can be on the riding mower and they will come after you from a nest 15 feet away under the house eaves. So I have a zero tolerence policy. Knockdown spray anytime I see any !! Plus the redhead is allergic to stings..BUT the vacuum sure sounds fun !br-549 wrote: I have taken the Rambo approach with a can of Raid wasp killer...
Ah, I worked Saturday and Sunday again so the Wasps are still in residence.
As for relaunching Scott, it's on my mind daily. I will have to re-do all new rigging on the exterior ropes. It's possible some will be okay but I don't sail on just okay anymore. Do it right or stay in port till you can do it right. Safety first.
Also it is so dirty right now I won't even tell anyone it is a Chrysler for fear of besmirching the brand. "No, no, that's not a Chrysler. That is a Bill and Teds Most Excellent sailing craft. I wish I owned a Chrysler!" Well something to that effect anyway.
Howdy Alan!
Good to hear from you again! Don't post as often but try an read to see what all is up. Hope you get back on the water in the spring!
Pam an I have 3 bee hives now an I don't like the wasp/hornet clan at all... no tolerance for them either. Bad for the honeybees!
Just started painting the inside of our project boat an then can start putting gear back on. We hope to be splashing next year!
Take care Amigo!
Billy
Take care Amigo!
Billy
- OutnBacker
Hello Alan,
Capt Scott has told me of you, another Chrysler sailor in the Area.
As to the Rambo Method of Wasp Warfare, I can attest to the exciting aspect of the hunt.
I suggest that you will need the following to insure success:
1) A good shop vac
2) that can of Raid, or other suitable Weapon of Mass Destruction
and...
3) a football helmet.
The latter will make sense as you read my testimony...
When I built my shop (Capt Scott has seen it), I did not immedeately install the outside lights, leaving the wiring hanging out a few inches through 1" holes where the connection boxes would go. Within a few weeks, yellow jackets moved in and created a nest of about 2000-3000 of the little nasties.
With the interior finished with sheetrocck, there was no way to effectively get at them with Raid, which I sprayed into the hole in copious quantities. It had little effect on the population and the fight became decidedly one-sided in their favor. Not to be defeated, I got my trusty Sears 16 gallon vac, with the two extensions, and stuck the end up to the nest opening.
At first, only the unfortunates who arrived as in-comers became victims of the gaping maw of the giant sucking wind tunnel. Eventually, the alarm was sounded, and dozens soon attempted to launch a sortie to drive off the attacker, only to meet their fates as they let go of the edge of the plywood siding. I could clearly hear the little voices of the doomed as they yelled, "EEEEeeeeee...!" Within a few minutes, the counter assault abruptly stopped. No more of the little kamikazies came forth. The word must have spread within the Borg.
A few continued to arrive, only to be sucked into the Deadly Vortex of The Sears-o-Cutor as I would send a generous blast of raid down the spout at intervals.
There was alot of very active and loud noises coming from within the wall, and I could tell the entire colony was locked in a serious discussion of what to do. Knowing there were at least a million angry little bastids in there, all hating me at once, I decided that a more direct approach would get them to give battle.
Here's where things went wrong.
I propped the vac hose up against the wall, just under the hole, and went into the shop to fetch a length of wood to use as a prod to pound on the wall, hoping to get the little buggers to come out. I found a junior league aluminum bat and went back out to beging the challenge.
I took up the vac hose in one hand, holding it just to the side of the hole, and with the other hand, I began to tap the wall. Nothing. I then began to pound a bit harder, really shocking the panel to maybe dislodge them and piss them off enough to get them to come out.
Boy, did that work!
They came pouring out that hole in platoons, then companies, then battalions. Within a few seconds, I was sort of thinking that maybe this was not a good idea. So far, the vac was sucking down all the bugs that came out, but soon as the flow reached the division level, a few got by and were actively seeking a target. Luckily, I was stock still, and they tried to attack the end of the hose extension, getting sucked into the tube. But some did not, and they were slowly figuring out that I was attached to the hose somehow. Perhaps I was emitting fear pheromones.
Did I say that this is where things went wrong?
Just about that time these little buggers were closing in on me, my doltish neighbor came up behind me and started heckling. Yes, heckling. Now, who would do such a thing at this delicate juncture? My doltish neighbor, that's who. To this day, he's still a dolt. but I digress...
Breaking my concentration, I flinched, or turned or something to acknowledge him, and , when I turned back to see what was going on, I was looking straight at a lone tiny warrior coming straight at my face.
Instinctively, I swung my right hand at the determined antagonist, forgetting that it held the Junior League Whopper. Of course, I missed the little ninja, but he did not miss me. I'm not sure what hit me first, the sting or the bat, but either way, I dropped the hose and ran, whereupon the remaining attackers were now unfettered. My neighbor stopped the heckling and the last thing he uttered as he fled for his life was something I can't write here, as the swarm went after him, not me.
Anyway, that was the part where I needed the football helmet. It would not have saved me a sting, but I would not have had to lie to my wife as to why my entire forehead was swollen from the single yellow jacket...
Good Luck.
1) A good shop vac
and...
Boy, did that work!
Good Luck.
Current: '78 Chrysler 20
Past: '78 Chrysler 22
'98 Bauer 12 - gaff rig
'78 Orion Malibu 18
'78 Orion Malibu 18
A handy tip I've used to 'collect' these creatures, at least Yellow Jackets;
Get a 7up or Sprite in a clear 2 liter bottle, and empty about 2/3's out, pull the labels off, then cut a small hole in the dome part. Hang near the nest and they'll be attracted to the sugar liquid and go in after it, but since the bottle and liquid is clear they have trouble finding the hole and will eventually fall in the liquid and die..
Works on our Gulf Coast critters, not sure about in the PNW or other regions !
Yes, Outbacker, good story.
This remedy is strictly for non-smokers.
Wasps, hornets (and rattlers) don't like gasoline fumes.
Toss three or four ounces of gasoline (do not light the gas) into the entrance hole they are using. Depart the area! They will leave and not return. This is best done after dark when they are all in the nest.
I have cleared vehicles (and small outbuildings) of wasps by disconnecting the battery ground cable and placing a tin can of gasoline inside leaving a window cracked open.
Wasps gone the next morning.
WD-40 is a good wasp spray in a pinch.
C-26
Hunter 29.5
Hunter 29.5
- OutnBacker
Had I known any of these remedies, I would have saved myself the grapefruit on my forehead. The loud "BINK" was audible for miles.
The one about the 2-liter bottle would be entertaining because of the visual, but I fear not in my case. When I declared victory the next day, I opened the 16 gallon vac and found that it was 2/3 full of yellow jacket corpses. I estimated at least 10,000 of the little pests. Alot of 2-liter bottles would have been needed, but I suppose I could have strung them together and turned them into yard art...
'78 Orion Malibu 18
'78 Orion Malibu 18
- LeatherneckPA
Outnbacker, great read, entertaining.
EE, I've used the 2L bottle trick with great success. I make mine a little differently.
- 1 ~ draw a line around the bottle at the top of the label
2 ~ then peel the label off a clear soda bottle
3~ cut the top 1/3 of the bottle off at the line
3 ~ invert funnel piece into bottom of bottle and scotch tape in place
4 ~ add bait of your choice, about 1/4 full
5 ~ they'll crawl in, but never seem to find the hole to get out, eventually they die or drown
Iron Mike - Semper Fidelis
1978 C-22: Believer
1978 C-22: Believer
- OutnBacker
"Outnbacker, great read, entertaining."
...and every word imperical truth.
On the Sectioned Bottle Method:
I have always hung a piece of breakfast ham from a tree branch when camping to lure the Great Cascade Mountain Yellow Jacket away from my repast. Perhaps a slice of that in the bottle would make a suitable bait.
'78 Orion Malibu 18
'78 Orion Malibu 18
- OutnBacker
Every time I hang up a slice of ham, it disappears in about two hours. The little thugs are relentless and varacious. They never fight over the meat, though. They just eat their fill and another takes its place. No time to rot. It sure does a good job of keeping them away from my cooking. It's just a variation of hanging a fish up.astrorad wrote:Sugary liquid won't spoil like the ham...and many people who have been stung in the lip will attest to how they like soda and beer cans.
'78 Orion Malibu 18
'78 Orion Malibu 18
