What is the replacment Harken cheek block for the C-22?
Is it still made?
Part number or way I can find it?
Should I upgrade?
Replacement cheeck blocks. What part number am I looking for
C22 Cheek Blocks
Not sure which blocks you are referring to. If you download the C22 Owners Manual, all the blocks are listed under "Small parts bag #2" in the rigging section. Any part numbers would be Chrysler part numbers though, and useless. You can check your line sizes against the specified sizes listed to see if anything has been changed over the years, but blocks are just sized by type and line size. Whether its Harken, Ronstan, or any other is pretty much irrelevant on a modestly stressed rig like a C22.
- OutnBacker
