Best way to remove rust stains from toe rail?
Posted: Tue Aug 20, 2013 6:34 am
by Zac Penn
Once we put the boat back on the trailer we are going to remove the toe rail and replace the screws with actual stainless steel hardware. The previous owners used standard screws because there are a bunch of rust stains on the aluminum. I tried CLR, MEK and Acetone and none of those worked.
Your help is appreciated.
Zac
Posted: Tue Aug 20, 2013 11:04 am
I've used Whink Rust Remover effectively before..little brown bottle
Like Here
Posted: Tue Aug 20, 2013 11:39 am
by parared
No help, but this last weekend I was giving Dia a bath. So I'm working in the cockpit scrubbing in circles, when I start thinking 'where did all these rust spots come from?' I make almost two complete circles before I noticed my toe was bleeding
Posted: Tue Aug 20, 2013 7:37 pm
by briceburg
For removing and trying to make rust inert I've used Ospho before with great success [like cleaning a truck bed before lining it].
Since it's aluminum you probably don't need to worry about it rusting more though; so maybe some ospho and then just anti corrosion hardware to cover?
You could also try polishing it off. That's what I do on my my '74 SuperBeetles cheap chrome hubcaps and they come back shiny. use something like Noxin metal polish.
Can you take a picture of the toe rail when it's off? I need to replace mine because I think it's a source of water getting in... [C26]
~ Brice
Posted: Fri Aug 23, 2013 10:35 am
by Zac Penn
