Keel stuck up!!!!!!!
My swing keel on my C-26 is stuck in the up position, and the cable is broken, and the boat is in the water . Does anybody have any helpful ideas as to how I can fix this ? Is it safe to sail with the keelall the way up?
1978 C26 "Get Lost"
You can sail the 26 in lighter air with the keel up, I do with EE all the time. However if that keel comes loose and slams down ...you risk a hole being blown in the back of the keel trunk at worst and at best a crack there...
Afraid that fix is safest handled with the boat hauled and on stands..and nobody under that heavy chunk of metal when prying it loose too
- thepartydog
