Need help on a part
Posted: Fri Apr 20, 2012 9:35 pm
by jbbkamp
Drawing a blank on the sailing term for the rubber jib "cleat" on my C20. Thinking about replacing them...they're brittle and let the jib sheet slip in a good breeze. Any ideas on a good place to get them?
cleats
Posted: Sat Apr 21, 2012 5:20 am
by David Anthony
They are either jam cleats or cam cleats. Defender.com has good parts
Posted: Sat Apr 21, 2012 8:54 am
by cs3079
.... or clam cleats .... and yes, they're kinda cheapo! I've got em on both boats for the jibs.. for now. My Widgeon had cam cleats. They hold much better, but the set and release is more deliberate. Cam cleats will not let go unless you release 'em. They honestly haven't been a prob on my C-20 yet, the winches take up most of the pressure.
http://www.answers.com/topic/cleats-2
They're about $25 a pop vs $4
Posted: Sat Apr 21, 2012 9:46 am
by Beady
If you don't want to wait you can also pick them up at West Marine.
Posted: Sat Apr 21, 2012 10:28 am
by Dallasbob
He's in Des Moines . . . No WM for several hundred miles. Defender may be the best option.
Need a Rubber Assembly
Posted: Sat Apr 21, 2012 7:02 pm
by Andy
My rudder assembly for my '70's era Buccaneer came apart. Anyone have a lead on a replacement?
Posted: Sat Apr 21, 2012 8:33 pm
by jbbkamp
Thanks guys...now just need to check what center to center is on my jam cleats to see if I can match them up!
Posted: Sat Apr 21, 2012 9:00 pm
by Dallasbob
A heads up . . . Odds are you won't find a perfect match. Dimensions have changed slightly since our boats were built. West Marine has a great catalog. Try to get one. Defenders catalog is not as good but their website is better. Good luck!
Posted: Sun Apr 22, 2012 12:10 pm
by jbbkamp
Good to know...maybe I'll be caulking and redrilling. If I have to do that anyway, should I stick with the clam cleat or go to a cam cleat?
Posted: Sun Apr 22, 2012 2:34 pm
by Dallasbob
If it were my boat . . . Cams. I hate clams. When I strip all the hardware for painting almost all of my clams will be trashed. I love the ease and security of cams.
