C22 Rudder Question
Posted: Tue Oct 03, 2006 9:38 am
I recently removed the rudder asembly from my C22 and noticed that the nylon (?) bushings were a bit worn. They are about 1/16 of an inch oversized. The net effect being that the is play in the rudder shaft when it is installed.
My question is ... Is this amount of play acceptable? I personally would like a tight fit and eliminate all play but would probably need to replace the bushings (which appear to be just standard off the shelf thru hull fittings).
Any comments or suggestions?
Also, on the upper part of the rudder shaft where the tiller bracket attaches to the rudder post, the hole has been elongated. I'm thinking I need to drill the hole over size, press fit a bronze bushing, then ream to size. Or maybe just drill a new hole an inch or so further down the shaft.
Again, any comments or suggestions?
Andy
Andy
