suzuki
blu by you
suzuki
well i have the boat ready , i rebuilt the lower unit of the motor , then found i only had 40 and 60 pounds compression i pulled the head off and found a blown head gaket( glad it wasnt worse ) water would not run out of the water exaust due to pressure in the head , i keep learning. head gasket should be in wed. i may be sailing by friday
