Chrysler 26 Rudder Woes
Posted: Fri Aug 25, 2006 3:23 pm
Hello Fellow Chrysler Sailors,
I am leaving my first post in hopes that you may help with some advice regarding the kick-up rudder on our Chrysler 26 which continually kicks up and compromises our steering ability. During this first season with our boat, my ignorance regarding testing the rudder control lines while the boat was "on the hard" is coming back to haunt us. The existing line has no effect on raising and lowering the rudder blade. I am considering getting the boat to shallow water and getting in the water to remove the rudder blade and replace the lines. My questions are as follows:
1) Is it feasible to attempt line replacement while the boat is in the water? (we have no trailer)
2) From diagrams observed on the Chrysler Assoc. website, I assume there are two separate lines attaching at two separate points on the blade. Is this correct? Currently, there appears to be one line in poor condition, the loop end of which is exiting the rudder post.
3) How do the lines attach to the holes in the rudder blade?
Any insight you can offer is most appreciated. Many thanks to all those who have posted previously and contributed to my education regarding the C-26. I won't give up easily!
