Mainly, I need help
Posted: Tue Nov 08, 2011 7:41 pm
by Paul
The bottom portion of the main luff is different than the simple mains I have used. There is a line attached to an eyelet that doesn't seem long enough to use as a down haul. One of the sail slugs is attached to this line, but the slug above and below it are attached to the luff.
I'd appreciate help understanding this and its use.
Posted: Thu Nov 10, 2011 9:26 am
by skyking
Is there a chance that this is reef point?
Posted: Thu Nov 10, 2011 9:44 am
by Windward
Believe it's called a reef jackline, and it permits the sail to reef smoothly without pinching the cloth and with the new tack pulled all the way down rather than wedged up the track above the other slugs.
Posted: Thu Nov 10, 2011 4:04 pm
by Paul
The Amazing Jeff is correct again! I googled it and here is the explanation:
http://www.blumhorst.com/potterpages/Ph ... -album.htm
So aparently this is not a stock rigging on our C-22's?
Posted: Thu Nov 10, 2011 4:12 pm
by lecker68
yes he is my original sail on the 26 had the same thing.
