C26 motor mount
Posted: Sun Sep 25, 2011 7:55 pm
by dennis
The motor mount on my C26 is in bad shape and has been patched up by the previous owner, I would like to replace it or rebuild it. I don't think my local marine store can help me. Is anyone out there building these or are there plans available.
Dennis
P.S. Sailboats are just plain fun, and sailing them, even better.
Posted: Mon Sep 26, 2011 10:50 am
by tgentry
I needed to modify mine to clear a big modern four stroke motor, but this might work for you as well. If you need dimensions I think I still have them. You just need access to stainless steel or aluminum (mine is SS) and a sheet metal brake.
Posted: Mon Sep 26, 2011 5:44 pm
That's a very common problem with the C26, that and the soft bit of sole right at the foot of the stairs....
Couple more threads with ideas/links to pics are
http://www.chryslersailors.com/discussi ... otor+mount
Posted: Mon Sep 26, 2011 7:40 pm
by dennis
Thanks guys, some good options. When the seasons over I plan to remove the motor and mount and see what I have to work with.
Den
Posted: Wed Oct 26, 2011 6:42 pm
by Tommy Monaco
Dennis,
Here is a link to a few pictures of the project when I did it last winter.
https://picasaweb.google.com/shoemaker. ... 5895601890
I went with powdercoated aluminum and about 20 bolts with 4200... needless to say the thing is pretty much bomb-proof. I think my buddy who welded it together still has the plans and could make you one. Let me know and I can put you in touch with him.
Posted: Tue Apr 30, 2013 5:33 am
by AlexisAnn
Posted: Tue Apr 30, 2013 7:10 am
by tgentry
Here is a rough sketch of my mount solution. I sandwiched the motor mounting area with 1/2" mahogany. My particular motor has an appendage that required some cutting away of the old mounting surface as well. Unfortunately I didn't realize that until after I had the motor on, which made it harder to do.
Posted: Tue Apr 30, 2013 8:06 am
AlexisAnn wrote:I just had one finished by a local shop. Kicked out an additional 12in and has less angle that the OEM version. I did this to accomidate a Honda 4 stroke motor. Now I can tilt the motor up and out of the water easily.[/img]
Welcome to the forum!
Tell us more about yourself an boat!
Photos are good too! We love to see all the boats!
Posted: Tue Apr 30, 2013 3:11 pm
by AlexisAnn
CaptainScott wrote:AlexisAnn wrote:I just had one finished by a local shop. Kicked out an additional 12in and has less angle that the OEM version. I did this to accomidate a Honda 4 stroke motor. Now I can tilt the motor up and out of the water easily.[/img]
Thanks! My name is Hunter, the boat is the Alexis Ann. This is my first sailboat. In the process of redoing just about everything. Picked it up from a guy in Nashville last year. It is a 1977 swing keel C26.
Replaced the electrical, motor, transome, starting the carpet. Updated all the lights to LED's, new bottom paint and stripes, refinished exterior woodwork and still working on polishing window frames and replacing lexan. Im sure the windows leaking is a common problem amonst most older boat owners.
[img]
[img]http://i1282.photobucket.com/albums/a539/ChryslerAlexisAnn/2012-09-30185600_zps2746da94.jpg[/img][/img]
[img]
[img]http://i1282.photobucket.com/albums/a539/ChryslerAlexisAnn/2012-09-20160105_zpscf160ee6.jpg[/img][/img]
[img]
[img]http://i1282.photobucket.com/albums/a539/ChryslerAlexisAnn/2013-03-31_125544-1_zpsb4167c64.jpg[/img][/img]
Posted: Wed May 01, 2013 5:54 am
Nice looking boat! Great way to start sailing too!
Again, welcome Hunter!
