				Window Removal/Replacement Questions
				Posted: Tue Sep 13, 2011 11:56 am
				by al the pal
				Posted: Tue Sep 13, 2011 12:07 pm
				by thepartydog
				Don't do lexan. It scratches too easily. I'll send proof in pictures if you don't believe me.
				Posted: Tue Sep 13, 2011 12:33 pm
				by turbo1168
				thepartydog wrote:Don't do lexan. It scratches too easily. I'll send proof in pictures if you don't believe me.
Seconded! Lexan is nearly unbreakable but is as soft as a grape, scratches if you look at it wrong. Plexi is very durable but much harder and doesn't get scratched nearly as quick.
				Posted: Tue Sep 13, 2011 4:12 pm
				I found out that although I replaced EE's plexi, and I cleaned the gasket up, I did not pay enough attention to cleaning the inside of the channel in the frame...had to redo them and was surprised how much grit I missed in there..
				Posted: Sat Sep 17, 2011 5:29 am
				by 38 special
				I found out through experience that most water leakage is due to the gastket failure. After removing a window, cleaning the frame and gasket I replaced it with the apropriate 3M sealer between the frame and boat. What was happening, is the water was getting between the gasket and window and leaking into the cabin of the boat. I am now in the process of special ordering some new gasket material from a window shop.
				Posted: Sat Sep 17, 2011 6:35 pm
				by astrorad
				Here is another option...
http://www.youtube.com/watch?v=sgXO44ooMo0...and
http://www.youtube.com/watch?v=u9COmXqLa50
The frames and gaskets are of the same construction on the C22, just a different size and shape.
				Posted: Sun Sep 18, 2011 11:36 am
				by hp18carr
				Al the pal
When a C26 showed up practiclly on my door-step... how could I say no, it had a cold nose and everything. Bleeding hearts at times do pay a price, case in point the windows. Each one on this C26 is destine to be an adventure... what I'm I saying this whole boat is an adventure. In the photo below is the portside aft window with interior frame. The rivets holding the frame were drilled out, will most likely reinstall it with small screws. There is so much old grit of different types over the frame and gasket, it may take days to safely separate the two. I've heard good reports about the butyl rubber seal route but have not crossed that bridge yet. Thanks for the up close photos of your window.
Chrysler C26' 1980
