Cushion Replacement
Posted: Sat Jun 18, 2011 12:38 pm
by bearley
Hi All,
Did the original settee cushions in the C26 have a thin plywood base? Mine do but I can't tell if it was original or added when the PO recovered them.
Posted: Sat Jun 18, 2011 12:48 pm
by lecker68
My 26 does not 1980 hatches in setee in salon have plywood cover.
Posted: Sat Jun 18, 2011 5:16 pm
by Dallasbob
Posted: Sat Jun 18, 2011 6:09 pm
by monty
no plywood on mine, they are original, I believe.
Posted: Sun Jun 19, 2011 12:26 pm
No plywood on mine, not 100% sure they are OEM. I'm thinking they are mid 1980 colors instead of 1970's colors so I have my doughts as to there origins.
Posted: Sun Jun 19, 2011 12:48 pm
by Dallasbob
I don't think a manufacturer would go the plywood route. I think they would want a higher quality look for prospective buyers flipping the cushions. I'm glad mine came from the PO that way because I had never seen it and it showed me a way to escape having new cushions done professionally. Something I can afford and cheaply. Custom stuff is way too expensive for me.
Posted: Sun Jun 19, 2011 6:38 pm
by mcrandall
Bob T-
Please post a picture when you get a chance! Cheap and easy, that was my nickname in high school....
Posted: Mon Jun 20, 2011 5:12 am
by hp18carr
Cheap and easy... no offence, but it may not fit now that you are older. I did a little shopping around to get a ballpark figure on the cost of building a free standing lift system likes yours, again very nice by the way. I don't recall if you did, but I chose to go with treated lumber and S.S. hardware where I could... it maybe my own doing but my ballpark is hovering around $1000. :shock:
Chrysler 26' 1980
Posted: Mon Jun 20, 2011 6:56 am
by mcrandall
OK, I admit, I'm not so cheap anymore....
Tell you what, I'll re-price mine out next time I go to the lumberyard, but I don't think I have much over $300 into mine. (Come-alongs and straps NOT included.) Granted, mine is smaller by a section than what I would make one for a C-26, but.... Also, I know my lumber was on sale, but that shouldn't make that much difference
I used zinc coated hardware. Let you know what I find.
Posted: Wed Jun 22, 2011 11:06 am
by NYCSAILOR
Just redid my OEM cushions for the C-26.. had it done professionally with sunbrella and memory foam in the v-berth...2G's.... figure it is was needed, would take me forever to sew ( I don't know how but have a machine) , a once in a lifetime project, would enhance the resale value ( something has got to help!) and I would enjoy each time I am onthe boat....
THe OEM salon settee seat BACKS were backed in plywood that was then screwed to alum angle brackets to the inner hull liner...
BTW: I thought about changing the configuration a bit and making thisngs more comfortable or more flexible seating or more modern... but that became a big project in and of itself and I realizzed I was just delaying getting it done...so now it is done...
I still ahve to paint hte interior white ( is still OEM "almond" ( I know I should have painted FIRST and then put in the cushions...)
cshions
Posted: Sat Jul 09, 2011 5:31 am
by blu by you
i just started recovering mine they have fabric on one side and vynil on the other and they are original, i am using the plywood method it is MUCH easier and a lot cheaper
Posted: Tue Jul 12, 2011 12:02 pm
by NYCSAILOR
The OEM cushions did have durable vynil on the bottom, I did the same with sunbrella on top... if you go the plywood method -- be sure and use stainless steel or alum staples!
duh!
Posted: Tue Jul 12, 2011 2:30 pm
by Papax3
You guys are brilliant!!!
You just minimized the pain of my next big project....!!!!
redoing my cushions as well!!! Now that I'm thinking about it,
the plywood/foam/fabric/staple-gun method seems exceedingly simple.
Why didn't I think of that?? I'll use a bigger foam pad and compress it alot, I think. Gotta make it comfy.
Thanx!
