mariner wrote:Does anyone know are there any differences in wire terminals? Harbor freight has kits that have a Tom
N of terminal for not a lot of money, on the other hand west marine has individually packaged terminals that add up to a lot more... So in reality what are the differences? Are there any or is it all bs to some degree?
It is all BS to some degree.
However . . . . . .
( you knew there was more . . . .)
The crimping tool and how you use the tool can make all the difference in the world!! I can not say enough about what I will share. You can save your self some very serious grief by listening to what I say or . . . Not. Your call.
I'll preface what I'm saying with a little know fact. In my youger days, I used to install car stereos and car phones in very high end cars. I know all about good crimp connections and bad ones.
OK, lets say you go to Schucks or Sears or wherever and by a kit with a tone of connectors. Butt connectors, bullet connectors, barrel connectors, spade connectors and of course, it came with crimpers. You know the set. We've all owned probably 2 or three of those sets. The very first and very best thing you can do with this set is open it up immediatly. Get the crimpers that came with it and immediately destroy them. Then, throw them away. Seriosuly, NEVER use these cheesy crimpers!! NEVER!
Yeah, I know. there are a lot of you rolling your eyes. thinking, I've used them for years! Never had a problem! Fine! Stop reading right now and enjoy your work. I have no heartburn with your choice. However, do not come to me with your wiring problems.
Ok, still reading? Then just mabye you have experienced the car stereo that cuts in and out. Speakers that go off and on, etc etc. Let me try and explain a couple of critical things most NON wiring do-it-yourselfers don't know.
Get a set of those cheesy crimpers and look at them. CAREFULLY. Look at the part that does the actual crimp. Look carefully. It has two very basic problems. First they are always to narrow. IE when you crimp the crimp itself is SO narrow it can and will weeken the wire. Yup! Great crimp but three weeks later the wire breaks! WTF you say to yourself so you put in wire ties for strain relief and yet you still have issues! Well, that is one
reason. So what do you do? Double crimp! YEah! NOT! same problem.
PLEASE HUMOR ME. Get your current crimpers. A piece of wire. and a connector. Crimp the connector to the wire and safe this. I want you to look at your crimp you just made but not until you have finished reading and doing my suggestions.
OK, the second issue with these cheasy crimpers and by far more important than the first and I REALLLLLLLLLLY hope at least just one of you try this and report me right or wrong. This is a two stepper to do it correctly but it is SOOOOOOO easy and no lay person know it! I did not know it until I was tought. Seriously follow this and if you are confused and have questions I will take your call and describe it personally to you so you get it right every time.
Back to your crimpers. get them and look again at the actual crimp part.
You will see the crimp is shaped like this -->> () <<-- you strip the wire, shove it in the hole, and crimp! Yeah! now grab the connector in one hand and the wire in the other and give a nice firm tug. You'll likely pull the connector right off! NICE CRIMP. Can you visualize that! seriousl, go get your crimpers and look. Now do a crimp link you normally do and I bet you get a 25% or worse failur rate. Good luck.
Now go buy GOOD crimpers and use them properly . . . . .
( yes there is more . . .. )
What are good crimpers? Well the very first issue raised: A nice wide crimping surface. This takes more strength to get a good crimp however decent crimpers are built much more solidly with slightly longer handles. Yeah! Better leverage and less strength required! Next item in good crimpers. They offer better than the simple "half moon " crimpers. a crimp that looks like a half moon on one side and a v on the other side and crimps like this --> (< <<--. Yeah, a minor but critical difference than the two half moons that are like this --> () <--
Ok, now you spent 30 bucks on a GOOD set of crimpers lets for the very first time in your life use them properly and this is where it is hard to describe a very simple concept. AGAIN, this minor concept is critical for a proper crimp that will last years. This is the difference between a job and a job done well.
Get one of your crimp connectors. Put on your reading glasses. Look straight down the barrel in the hole of the connector where you are shoving the wire. Look very carefully. You will see the barrel of the connector is made of probably aluminum and is like a cylinder however the cylinder is not a closed loop. It is more the shape of the letter C that was closed so tightly it looks like the letter O. There is a seam.
OK put the connector in your crimp tool and hold it firm enought to hold but not crimp. Now rotate the connector so the seam of the connector is centered on the "half Moon" part of the crimp tool. The "v" part of the crimp tool will be centered on the "NONE" seam section of the connector.
Now put a wire in and crimp it firmly. Go back and look at the crimp itself. It should be nice and clean with a very nice wrap around the wire! For giggles take a second connector and intentionally rotate it the other way and crimp. Look again and the bad crimp! You should see a dramatically UGLIER crimp! The second will not hold as well as the first.
Yep! It is that simple!
Heh heh! Now go look at that crimp you made at the beginning! You just might get a big surprise when you see what you've been doing all this time!
If you have further questions, seriousl feel free to call me. I will happily detail further any aspects of this.
FYI I use Klien Crimpers
I have no interest in the company other than I use no other crimpers than these. All other crimpers that come into my garage get either thrown away immediately or they are not allowed in. This includes two weeks ago when my son came over so we could replace the struts in his WRX. I found his cheesy crimpers in his back seat. I threw them away and gave him one of my Kliens.
http://www.service.kleintools.com/Tool/ ... CRCTNINSIN
I beleive Sears sells Kliens now.
