Splashed & Delivered, but...
Posted: Fri Apr 15, 2011 6:36 pm
Yesterday was the day... and a beautiful day I might add (mid 60's, sunny, 5-10 kt winds from the NW) perfect timing to finally get the boat splashed and delivered to her new home. All the major winter projects were done (motor rebuild, new motor mount, new throttle and shift cables for the motor, bottom paint, fixed rudder cheek, compounding and waxing). She was in the slings when I pulled into the marina... what a beautiful sight, her red hull gleeming, contrasted by the fresh black bottom. After a little tinkering with the new control lines we finally got it all hooked up and ready to go! The engine even started with only a little cajoling. BTW, I don't know if anyone else has started doing this, but now is as good a time as any to suggest it: I've started only running airplane fuel for my outboard and I highly suggest it. It is ethanol free, 100 octane, low lead and has about twice the "shelf life" of your standard unleaded. You can get it at most any small commercial airport, but it does cost about twice as much... well worth it if you asked me. Cheaper than a rebuild and in the grand scheme of things. How many gallons are you really going to use in a season? Treatments are fine, but there's no substitute for having NO ethanol. I'm sure I could find a marina that has non-ethanol fuel too, but the extra octane and the little bit of lead just seem to help the motor run better. Anywho, I digress...
So, we get the motor running, but.... and here comes the start of it all... no reverse. Pfft, no big deal, right. Tons of sailboats don't have reverse and learning to rely on the motor less would be a good thing. Still something I'll need to check on. Anyone with a little knowledge on Yamaha 4-stroke outboards? I would love any help (it's the gearbox, not the cables, when I unhooked the cables and manually tried to put the engine in reverse gear, it still wouldn't engage.)
But... after a quick check down below and seeing everything was ship-shape, we took off for a quick scenic cruise past iconic Thomas Point Lighthouse and eventually past the majestic spires and domes of Annapolis. Quite a sight from the water! If you've never sailed the Chesapeake Bay, make it a point to at some point, it truly is a sailor's playground!
Call it diligence to safety, call it paranoia, call it providence or intuition, but about 10 min after taking off I check the bilge again.... GASP! A LEAK! A bilge that could've passed for the Sahara last season is now sloshing about with the very stuff I'm trying to keep OUT. Call SeaTow! Call the Coast Guard! we're going down! Well, that is until my buddy (with ages more boating experience than myself and he was along for exactly this kind of calming demeanor) comes down and chuckles "That's not a leak, it's just seeping" Seeping, leak, whatever... it's water coming in, no matter how slow, and that means: I don't like it. We determined that its "seeping" in from the knotmeter thru-hull, but not enough to turn around or stop, so we kept going. By the time we got to our new slip, it really was just a seep, because the bilge had barely collected much more water. However, an ever present drip could be seen running from the knotmeter down to the bilge. My knotmeter is located port side, in the same compartment as the bilge access, just behind the galley.
I pumped it out (I only have a manual pump) and made a quick run to the store for some 4200. We first tried to tighten everything down with some channel locks, but the plastic fitting, is either OEM, or pretty darn close and looked a little brittle so I really didn't feel comfortable tightening too much, and it didn't help slow the leak at all either. I decided that the best course of action was to seal it off, and gobbed enough 4200 on that thing to nearly encase it. After waiting an hour or 2, I checked again, and the leak had slowed to almost nothing and after putting some more on this morning, I'm pretty confident it's done.
BUT, that's only a temporary fix. I'm not really too sure what to do next here. Haul it out again? Is there anything I can do while it's still in the water? None of the other thru-hulls (sink drain, depth) are seacocks, am I to expect the same from them soon too? I don't really use the knotmeter... as blues legend Howlin' Wolf sang "I'm built for comfort, baby, I ain't built for speed". On top of that, it's never worked anyway... Depth went out too, 2 weeks after I bought the boat last summer.
I'd love to hear any suggestions, what you guys have done already and what you think would work best.
