C22 flotation foam and water
Posted: Tue Mar 21, 2006 10:56 am
Hi all -
Here is a question that I have yet to see posted on this site. As you know, there is flotation foam encased in the fiberglass under the area that a sliding galley would normally slide as well as other areas inside the C-22. In most areas where there are holes (where I assume the foam had been originally injected) there are silver caps over the holes.
However in the space in my boat where the sliding galley would normally slide - the caps were missing. During storage this winter, water seeped into my boat and into the uncapped holes.
I'm wondering if the water that went into the holes is just resting on the foam and will eventually evaporate, or if water that has gone into the holes soaked into and through the foam and there is now moist foam in contact with the hull - which could lead to problems down the road.
I guess I'm wondering what type of foam they used - open versus closed cell foam.
If I do need to take steps to extract water from the flotation foam - is there a way of doing that without having to remove the majority of the foam?
Anyone have any thoughts on this?
Mike
Mike
