Roller furling headsail
Posted: Wed Mar 02, 2011 4:21 pm
by RGS
I have a Sandpiper C-22 and need a roller furling headsail for it I believe I need a #5 luff tape.
Thanks for your help
Posted: Sun Mar 27, 2011 10:00 am
Group, I just found this thread down in the Starwinds Wanted section and moved it here for replies
EE
Posted: Sun Apr 03, 2011 4:18 pm
by lecker68
Check Atlantic sail traders
Posted: Sun Apr 03, 2011 8:12 pm
Hi RGS,
Sorry I did not see this thread till now.
I looked into a roller furller for my C-22 back when I first got her. I found it could be done with lots of money. More money than I paid for the boat that is. I decided not to get the Roller Furller. Sure it would be nice but not really necessary. I thought sailing alone it would be a must.
Nope, I sail alone all the time. I tie the tiller off and raise the sails alone. Then when I'm done I head into the wind, put the boat in irons, tie off the tiller and take the sails down.
Now an auto tiller, that would be worth the investment to keep her in line while my sails are going up or coming down.
Basically I figured $1500 to $2000 for a Roller Furller or $400 for an Autotiller. I would get far more use out of the Autotiller then the Roller Furller. Plus I got good at doing the sails single handed as a novice sailor. I'm claiming to be an a rank amateur sailor now. :lol: And after only 2 years of sailing my C-22 I gave myself that promotion. :lol: :lol:
Try it you'll like it.
I could not find a photo of how I stow the Jib on the deck in the pulpit when I head out for a day of sailing. See this photo for refrance.
I clip all the clips from the jib onto the forestay. I then hook on the halyard from the mast to the top of the jib. I then run a bungee cord from one side of the pulpit to the other, over the folded up jib laying on the deck sitting inside the rails of the pulpit. I get out to sea, pull off my bungee and haul on tha halyard and my jib is up in like 2 minutes. It comes down just as easy and the bungee goes back on the jib and I sail home. I put the jib in its bag at the dock and stow it in the cabin. Easy Peasy.
Posted: Mon Apr 04, 2011 5:01 am
by Jmckamey
Alan, I like the way you have rigged the jib to clear the railings. I'm going to see if I have enough room to do the same. Looks like it makes life easy on those expensive sails.
I just noticed you have a pop top boat. Do you have the inclosure that can be used with it? A friend of mine has a pop top and I wanted to show him what one looks like. I think I could sew one.
Posted: Mon Apr 04, 2011 10:43 am
by back2class
Jmckamey wrote:Alan, I like the way you have rigged the jib to clear the railings. I'm going to see if I have enough room to do the same. Looks like it makes life easy on those expensive sails.
Doing that will throw your boat off balance some. You wan that sail low if at all possible. Can be a little obtuse at times though.
Posted: Mon Apr 04, 2011 11:14 am
by mcrandall
That's acute statement.... :oops: :wink:
Posted: Mon Apr 04, 2011 11:35 pm
I find I can indeed sail closer to the wind when the jib is down on deck.
It is up about 24 inches for my convenience only, not for performance. Someone eles pointed out that my having it up off the deck like that moved my force of the wind and sail hire which was not good.
To be honest I sailed with it up off the deck like this for a year and I like it. Many a boat, not a Chrysler, in my size can't get away form me when I'm chasing them down. I've had several other boat styles comment on that. I even had 1 Chrysler 22 that I was able to catch, but my sail was down on the deck that day. Come to think of it that was the last day I sailed with the jib down on the deck.
I like the view better with it up off the deck. The sail does not get banged up on the pulpit ether. Tacking is easier with everything over the railings. To be honest I don't notice any balance issue. This may be that I'm just not that good a sailor to notice the difference in balance. The nice thing about the way I rig it is I can drop it back down on deck real fast with my setup if I want to while under way. It's just a nylon rope about 2 foot long with stainless connectors on both ends.
