Lifting a C-26 to remove the keel - without a crane
Posted: Thu Feb 10, 2011 9:21 am
It's getting close to that time of the year where another boat load of projects are to be done.
One major one that everyone wants to have done but is exhausted just thinking about it, is to jack up their boat and rebuild the keel shoe/pin on a C-26.
I have read as many posts as I can find on the subject and there are some great ideas on how to jack her up, remove the trailer, and drop the keel but it still has to be done by me.
I came across a website the other day where a fellow had a really simple method of lifting his boat and I thought I would share it with everyone.
His ship is smaller than the c-26 but not by much so I think this will work well.
Just another note for those of you out there interested. An engineer I work with did some calculations and said that a safe load number for a spruce 2x10 (*** on it's narrow edge, with zero side flex ***), with supports at either end (10 feet apart) can handle 1500 lbs. of central downward force. Hence 3 nailed together can handle 4500 lbs.
I hope i explained that right.
Anyways, here is the link.
http://rjlesyk.com/Building_Steal_Away_8.html
For those out there who have taken their keel out and rebuilt the shoe, there is one thing I don't understand. How is the shoe connected to the boat so that it is stronger than the shoe assembly? If you don't have that answer can you just tell me what the shoe bolts into? Are there steel plates glassed in the hull that it bolts to?
Adam
Adam
