Sliding Hatch
Posted: Tue Dec 27, 2005 2:28 pm
by Zilbub
I would like to install something for the sliding companion-way hatch to slide on and still have the teak slides holding on the hatch. The hatch slides on the cabin top and has started to wear the hatch and the area on the top where it slides. Is there any kind of "strip" or something else someone has installed to address this problem?
Posted: Wed Dec 28, 2005 6:33 am
I have same problem on my C26...am considering trying a thin phenolic strip laminated to the cabin top in that area...
maybe take a look at:
http://www.mcmaster.com/
search for "phenolic", and then choose "phenolic plywood" from the results.
Looks good
Posted: Wed Dec 28, 2005 8:04 am
by Zilbub
I checked out the site and the stuff looks pretty inexpensive so I ordered some. Thanks for the tip...
Posted: Wed Dec 28, 2005 9:08 am
which thickness did you get ? I'm still waffling over that..I have a fair amount of slop between my rails and the cabin (enough that Katrina lifted one side of the hatch loose, lucky the other side held) so I'm thinking of going thick enough to take care of that..
good luck..
Posted: Wed Dec 28, 2005 9:23 am
by Zilbub
I ordered 2 of the 1/32" X 2" X 48". I plan to cut it in half, lengthwise and use some on the hatch itself as well as on the deck. I won't know for sure until I actually see the stuff but it was under $8 including shipping so I'm not out much if it's not what I'm looking for. I'll keep you posted if you want once I get the stuff. It's coming ground shipment.
Ultra-High Molecular Weight Polyethylene(UHMW)
Posted: Wed Dec 28, 2005 9:52 pm
by Wag4513
I have UHMW strips to use, weather resistant, low friction, and high impact resistance. I have it wide enough to go under the teak rails and be held by the screws that attach the rails. Also I have neoprene to go under it to provide a water seal, since I belive adheasives won't stick to this stuff.
Rectangular Bar 1/8" Thick, 1/2" Wide $0.56 per Ft. Sold in 5' lengths.
This also available at McMaster-Carr.
Jim
Posted: Thu Dec 29, 2005 7:27 am
by Zilbub
I'll see how this other stuff works and should it not, I'll go back to McMaster. At any rate, I'll keep everyone posted.
This is GREAT!!!
Posted: Sun Jan 15, 2006 6:22 pm
by Zilbub
I happened to go to Action Sailboat to in Andover, Kansas to pick up some supplies and mentioned my hatch problems. He sold me some thick, teflon tape that is used in the same application for a Catalina 22. I put in on the runners of the hatch and on the deck where the hatch slides and it works great! For any of you who are needing to do some hatch repair, this stuff is just what you need.
Posted: Fri Feb 17, 2006 5:58 am
by slidejob
I fixed mine using 1/8" starboard. It works great!
Mike
