winch
Posted: Fri Jan 21, 2011 9:01 am
by John Stahl
The Winch on my C26 trailer is shot and I need another one. What size do I need? 2000, 3000 LBS or more?
Posted: Fri Jan 21, 2011 10:02 am
by skyking
I have a 3000# on my C22 and that seems to be enough, but I would tink that something in the 4000# range should be sufficient...
Maybe someone with a 26 will chime in with some insight!!
Posted: Fri Jan 21, 2011 11:36 am
Might find a bit of helpful info on the original winch here:
viewtopic.php?t=415&highlight=winch+brake
Posted: Fri Jan 21, 2011 11:59 am
by skyking
Wow !!
I really went overboard, But it does come in handy when cranking up on a steep ramp
Posted: Fri Jan 21, 2011 12:19 pm
Whoa, back up. I misread the thread. Trailer winch, I was reading keel winch. Disregard.
C26 weighs at least 5500 from the specs..think big.
Posted: Sat Jan 22, 2011 8:07 am
by SN691
John my trailer is a EZ LOAD with rollers. I replaced my winch last March because I lost the winch handle and the winch was all rusted up and the cable had a few broken strains. I replace it with a Fulton model T3205 with 3200 lbs 1 layer and 1450 lbs full drum from Eastern Marine. It is the same winch that was on the trailer.
Posted: Sat Jan 22, 2011 12:57 pm
by mariner
I did the same thing last year, I had a cable snap and said no more! and switched to a belt. (we were lucky no one got hurt) I purchased a new Dutton Lainson DL1402A Standard Ratchet Hand Winch ($39.30) which is the OEM brand, the holes lined up perfectly and then I got a Hand Winch Strap with Safety Hook, 2" Wide x 25' Long - 4,000 lbs. ($15.94). I purchased both on line from two different vendors. the prices are with shipping! not a bad deal. If you do a web search and compare prices you will find some good deals.
