Hi folks, another question for your advice.
My C-26 has a thin foam rubber lining in the aft berth area under the cockpit that is disintregrating and falling off.
I am thinking of wire brushing the inside of the hull, and just plain painting it with a light paint. (some kind of latex enamel)
Pro's ? Con's? This are will be used more for storage than anything else. \
Anyone else done this?
Thanks in advance for your collective wisdom.
Eric in Sioux Falls
Interior question
i have this too..
it is a mess.. thinking of cleanign it off and laminating a nice wood veneer to al lthe surfaces with glue but did this in the head and it is a ot of labor...
bumping this thread...
the OEM fabric and foam padding all over my interrior is fallin off the sides and cieling...what is the best removal method and what hve people replaced the foam /fabric walls with ..paint.....I don't want carpeting and I am thinking of something nice like wood slats or so...but best removal methods/practices would be helpful
Well, the method I used on EE might be of little help to you ! After gutting the interior, I climbed in with a pressure washer, had the bilge pump running, and went at it !
I did find a product called "Goo Gone" that worked wonders on the leftover glue on the interior gelcoat - that might help you on the rotted foam, I found it after I pressure washed.
http://my.att.net/p/s/community.dll?ep= ... 280783&ck=
Also if you need a paint match for the stern, I have a tip here:
http://my.att.net/p/s/community.dll?ep= ... 291853&ck=
[quote="NYCSAILOR"]bumping this thread...
I have the same problem with my liner. EE when you redid your liner did you repace it with fabric, use vinyl or did you paint it?
1979 C-26
Easy Street
~~~_/)~~~
1979 C-26
Easy Street
~~~_/)~~~
