A photo log on the refit of Puffin
Posted: Mon Nov 29, 2010 7:07 am
I thought I would make a photo log of the work I am doing on Puffin. I thought you may enjoy watching its progress.
http://s1082.photobucket.com/home/fivemoremiles/index
Here are some of my goals.
!. Puffin must be in the water in 2011.
2. Try to increase Puffins resale value----I know I am dreaming
Here is a list of the refits that I need to do.
!. Reinforce the sole under the cabin steps
This is priority one
2. Reinforce the cockpit benches that creek.
Since I will be using fiberglass on the sole it make sense to do this repair at the same time
3. Reinforce the mast step
Again this is fiberglass work and makes sense to do it with the other fiberglass work
4. Replace the lines
Goal to finish the above refits before summer of 2011
Since the cabin will be striped not to go further till we get her in the water and test her for leaks so we will stop there.
Projects for next year
Restore the cabin door.
Lighten up the cabin. It is not a cave.
Refit the galley
Remodel the hatches so they will let more light in, and open easer.
Refit the galley
