Outboard Advice
Posted: Thu Oct 14, 2010 11:34 am
by Lucky Jack
I am trying to find an outboard that will work on both a Chrysler 22 and a Victoria 18. What I have in mind is a 3.5 hp four stroke Tohatsu:
http://www.onlineoutboards.com/Tohatsu- ... 3-5BL.html
It's more than enough for the Victoria but is it strong enough for the Chrysler? At the moment I sail exclusively in lakes so no currents to deal with. I've been haunting the local Craigslist, but so far the prices I've seen there are no bargain.
Posted: Thu Oct 14, 2010 1:32 pm
For relatively calm flat water that outboard is more than plenty to get to and from the dock or piddle around. However if you are in heavy winds or anytype of seaway you may find it lacking in ability to power home.
As a sailboat that should not be an issue since you could SAIL! but just be aware in 20kt winds you may not have enough.
Posted: Thu Oct 14, 2010 4:19 pm
I'll second that, my 6 hp has power to spare so as long as you are not having to fight heavy currents or tides, winds you should be fine.
Posted: Thu Oct 14, 2010 4:31 pm
by heekee
I got a great deal on a 1975 Johnson 6 horse recently. I was having trouble with my 1985 Evinrude and this old motor purrs like a kitten. It seems to be perfectly balanced for my 22 foot.
Posted: Thu Oct 14, 2010 6:03 pm
by Mario G
I would say a 5hp would be the smallest you would want on a C-22.
I just had more issues with our Evinrude 9.9 but I think it gould have something to do with the 18" of rain a few weekends ago. (water in the gas maybe
Posted: Fri Oct 15, 2010 6:18 am
by Capt. Bondo
Posted: Fri Oct 15, 2010 8:17 am
by hp18carr
Not to be the one to drag this post past it usefulness, but at some point I'll be installing a new motor on my c26. Capt. Bondo's statement of having the power when you need it is valid... but is there a happy medium between power and weight? New motors with a H.P. of 9.9 or higher seem to weigh in around 80 to 90 pounds and we all know the motor mount on a c26 is not the strongest in town. In a nut shell... I'm I destine to reinforce my motor mount to the point where it looks like a mini fork-lift.
Chrysler 26 1980
Posted: Fri Oct 15, 2010 11:08 am
by Lucky Jack
Thanks everyone. The problem is that motor is about the biggest the Victoria can handle weight-wise. Maybe best thing to do is get that motor since the Victoria has to have one anyway, and then see if it will work at all on the Chrysler.
Posted: Fri Oct 15, 2010 3:12 pm
by mga1951
On a side note about horsepower. I have a 9.9 Mariner on mine w/ electric start. I had a new 4 stk, 6 hp Merc. Realized if anything happened to me, my wife would not be able to pull the cord hard enough to start the motor.
I dislocated my shoulder 2 yrs ago and then it hit me. I need an electric start outboard.
just an idea to think about!!
Posted: Tue Oct 19, 2010 6:55 am
by mariner
I replaced my chrysler sailor with an electric start tohatsu 9.9 four stroke and use the original mount, with no issues, i love the motor! its perfect, i never really push it much past idol but when i do , boy does it move!
Posted: Wed Oct 20, 2010 12:48 pm
