Things are moving along more slowly than I wanted. The mast is almost re-wired but with additional lights which will require adding wiring internally to my C-22.
At the nav station I currently have a volt meter about 3" diameter (going from memory so I could be off on the size). To its left is a 3/4" - 1" hole where one black 22ga wire with a female quick connect is sticking out. What instrument am I missing that this should be attached to?
Navigator's Station Question
Hey Paul Pictures...lol , not sure where your nav station is on my C-22 it has the basic wiring and lights with just a 3 position light switch on the cockpit controler.
A fishfinder would be a great insterment to have if you can see it from the cockpit. A VHF radio could be what you had there.
Hope things work out soon so you can enjoy.
- Andiron120
Sorry for the lack of pictures. Seems my camera crams too many of those pixel things onto the memory card and I haven't experimented with how to reduce them to make them managable on the site (It's the same reason I don't have an avatar).
From your answers my guess is the 3 way switch because there is no other place on the boat to turn on the nav lights.
- surveywaters
