need a new tiller
I'm currently testing a tiller of my own design with a higher rise and shorter reach, for more confort at the helm and to give us more room in the cockpit. The prototype was just cut out of a 2x6 with some fender washers to fill in the space at the mount. Once I finalize the design I'll make it with nice wood
- thepartydog
Darin
I'm hoping the protptype will stand up to the stress under heavy weather, but have not had a oppturnity around here lately, works great under power
I'm keeping my origional tiller on board just in case.
The laminated tiller will be a winter project.
WOW! The tiller snapped?
I've never seen that happen before.
FWIW I had a tiller on one of my C22's that had seperated from itself. The individial pieces of wood were OK but the came apart from each other. I sanded smooth and cleaned it up best I could then glued it all back together. I used wire ties to hold it together about every two inches. Worked perfectly. Once the glue had set I cut the ties and sanded the excess glue off. Next came cetol and it looked/worked great!
