C-22 Boom/Main Sail Rigging
Posted: Tue Jun 29, 2010 2:24 pm
by Zahger
Hey Everyone! Was just wondering if anyone had some good pictures of their boom/mail sail rigging. I have the Jib all figured out, but am trying to figure out where to rig all the boom stuff up.
Thanks for any information!
Posted: Tue Jun 29, 2010 3:44 pm
by skyking
I dont have any today, but I can get some for you by friday if that will work?
Posted: Tue Jun 29, 2010 3:56 pm
by FranS
Try this
Posted: Tue Jun 29, 2010 7:27 pm
by Zahger
I just don't understand what I am supposed to tie the end of the boom off to.
There is some track system along the stern of the boat with a little piece that can glide along it, and there is one pin to stop the gliding piece at various spots.
Posted: Wed Jun 30, 2010 2:14 am
by trev
The track would be your traveler. You hook your mainsheet to this then to the underside of your boom to the rear most hook. Sent you a PM also
Posted: Wed Jun 30, 2010 5:29 am
by Capt. Bondo
Zahger;
My c22 is sitting rigged on the St Croix if you would like to come and look and take notes drop me a PM.
Posted: Sun Jul 04, 2010 9:09 am
by Zahger
Thanks for the input. Looks like I could find all I needed in the Manual on the main site.
C-22 mainsheet and jib rigging
Posted: Wed Jul 07, 2010 3:06 pm
by davidhanson
Greetings, I have just taken possession of a Chrysler 22 and I'm also not sure of a few things.
1. Is there a mast lock up top for the mainsheet halyard on these?
2. Is there a diagram of which lines go through the pulleys at the bottom of the mast and to the locks?
Thanks for any help. I'll get this sucker running in no time.
Posted: Thu Jul 08, 2010 6:24 pm
by skyking
Here is a link to my photos...I hope that this helps...I dont have any type of lock up on top of the mast for the halyard....my main sheet is shown in the photos along with the goose neck attached to the boom & Mast.
http://s958.photobucket.com/albums/ae61/1961skyking/
Posted: Thu Jul 08, 2010 8:10 pm
by Zahger
Nice Pictures! Where did you get all the pins for the traveler? I only seem to have one.
Posted: Thu Jul 08, 2010 8:50 pm
by kokezaru
Hey Tim,
Your boat looks real nice. However, the Carabiner-style snap shackle that you are using to attach your main sheet blocks to you boom is not very strong, maybe only 100lbs. You could blow it apart on an accidental jibe. You would be best off with a "D" type shackle, they can handle 1000s of pounds, and are not very expensive.
Also, I noticed that your bow pulpit attachment points are close together on your deck, does that interfere with your jib?
Posted: Fri Jul 09, 2010 4:12 am
by skyking
Thanks Richard...
I will switch the carabiner style snap...I didnt realize that they were not suitable for the job..
As for the pulpit, its positioned there only because thats where I could get the best fit..I have a short cable that extends the jib up a little so that it clears the pulpit.
Posted: Fri Jul 09, 2010 4:47 am
It is not the carabiner style persay but the rating. They do make them with much higher ratings but yours look like one that is not designed to carry much load rather to just hook things together.
Re: C-22 mainsheet and jib rigging
Posted: Fri Jul 09, 2010 5:48 am
davidhanson wrote:Greetings, I have just taken possession of a Chrysler 22 and I'm also not sure of a few things.
Welcome to the forum!
I presume you've been looking at the photos here! As far as the lock on top of the mast?? No, there is not a lock for the main Halyard.
As far as the rigging, check this site out and the original owners manual!
http://chryslersailing.lizards.net/sail ... anual.html
You will find a lot of info there if you just poke around a bit!
