Page 1 of 2
New Shoal Draft Rudder Pictures - RUDDER COMPLETE
Posted: Fri Apr 09, 2010 3:20 pm
by amayotte
Hello,
I am in the middle of making a new shoal draft rudder.
Here are some pics.
The rudder is a Naca0017 design - 32 inches long, 23 inches deep and 5.44 inches wide at 30% chord.
I have designed it such that the rudder pivot point is at 15.6% chord thanks to Guillaume's suggestions.
She will then be filled with 2" blue polystyrene and then cut to shape using a hot wire.
Once she is shaped I will glass it altogether.
If anyone has any suggestions...don't hesitate.
Adam
Posted: Fri Apr 09, 2010 6:35 pm
by Paul the Denverite
I'm planning on getting ready to cut and glass blue styrene for my C-22 tomorrow. Did a test layup on the inexpensive blue insulation sold at Home Depot. It fits the bill! I'm planning two layers with carbon fiber between and then a schedule of 10oz woven mat, 6 oz uni running lengthwise, another 10 oz woven and a final 6 oz top layer. I debated on a layer of carbon fiber between the uni and the 10 oz woven because it would look cool, but it's over kill and I plan on painting the finished rudder anyway.
Posted: Fri Apr 09, 2010 9:46 pm
by Andiron120
Way to cool, looking forward to more pictures.
Posted: Sat Apr 10, 2010 8:43 pm
This looks pretty massive. What are you thinking the weight will be when done?
Posted: Sat Apr 10, 2010 9:55 pm
by amayotte
Paul,
It's hard to say how much it will weigh. I can't see it being much more than
what there is now.
It will be more just because I don't have a form to build around and am stuck using MDF...but i'm not too worried about it.
The trade off will be well worth it. I hate it when in shallow waters and I can't
steer because my rudder hits the motor.
All in all....rudder and rudder shaft...50 lbs.
Posted: Sun Apr 11, 2010 6:10 am
What is that core material?
Posted: Sun Apr 11, 2010 9:08 am
by amayotte
It's called MDF. Medium Density Fibre. It's a combination of glue and wood fibre.
It does swell really bad once wet but since this will be completely glassed I'm not too worried about it.
It's very cheap and extremely easy to work with and glue together.
More pictures...
Posted: Sun Apr 11, 2010 1:51 pm
by amayotte
Hot wire PICS
Posted: Tue Apr 13, 2010 3:53 pm
by amayotte
Here is the rudder after I went over it with a hot wire.
I have a huge question for those of you out there. The hot wire worked really well but there are a couple spots that need to be filled before I glass it. What would be a good filler to use? It would be nice if the filler is sandable so I can shape it to the rest of the rudder.
Thanks.
Posted: Wed Apr 14, 2010 4:32 am
by Mario G
I think kitty hair would be the filler your looking for. Can be found everywhere from auto part stores to our local marina always has it in stock.
its looking really good, I wonder if a high density spray foam woud work if you could make a mold around the rudder?
How close to the rudder on my fix keel C-26 are the diamensions is yours going to be.
I haven't gone under Shaken Knot Stir'd yet I hope to this comming weekend when I drop the mast.
Posted: Wed Apr 14, 2010 5:01 am
by tgentry
Nice work!
I would think auto body filler would work well.
Posted: Wed Apr 14, 2010 5:09 am
Go to a hobby shop and get some micro balloon filler, it is light and easily sanded. It's used for just exactly this use.
Posted: Wed Apr 14, 2010 11:56 pm
Posted: Fri Apr 16, 2010 3:51 pm
by amayotte
Banshi wrote:Go to a hobby shop and get some micro balloon filler, it is light and easily sanded. It's used for just exactly this use.
Is micro balloon filler the stuff you have to add epoxy to or is it pre-mixed and ready for use? Everything I come across needs some type of additive.
Posted: Fri Apr 16, 2010 4:38 pm
It is already mixed the stuff I have is made by hobbico but at the hobby shop it will probably be by another company. Here is what I have from towers hobby.
http://www3.towerhobbies.com/cgi-bin/wt ... LXL482&P=0
Posted: Sat Apr 17, 2010 8:50 pm
by Paul
Sorry it took so long for me to reply... lost my password. Beau was great getting me connected again.
To the micro baloon. They are the correct thing to use. The trick, though is that the foam is much softer than the micro so final sanding can gouge the foam and leave the micro locations too high. The best way is to make a sanding board at least two feet longer than the distance between your two cutting templates. A piece of aluminum angle from Home Depot works fine. Use spray adhesive to attach sand paper to the center of one face of the angle. Leave at least one foot on each end of the angle without sandpaper. You can now sand with an end of the angle on each of the templates. This will leave the templates accurate and bring your foam down to a nice smooth surface between them.
Another tip for glassing: Use 100% polyester on the very top layer and wet it in just like you would your glass mat. When it has completely set you can pull the poly off and have a very smooth finish but with microfractures that will hold other glass layers or paint very well.
Paul in Denver
Posted: Sun Apr 18, 2010 9:02 am
Micro Balloons and Tower Hobby links. I'm getting the feeling a few of us have cut a foam wing or two.
Or maybe made a wing fillet...
The sanding bar is the way to go, and another good tip is to lay some masking tape past the micro balloons area. That way if you do gouge anything it will be the tape, plus it gives you an indicator of when you reached flat between the filler and the foam around it.
Posted: Sun Apr 18, 2010 9:47 am
by amayotte
Paul,
I'm not too sure what you mean by this.
Of coarse I have to use epoxy to glass it since polyester will melt the foam. But your saying after all is said and done do a final layer of polyester resin? I don't understand why that would make a difference.
From everything I have read you can epoxy over epoxy as long as you sand and wipe with a small amount of Acetone.
I'm sorry but I don't thing I know enough about glassing to get what your telling me...can you clarify?
Thanks for all the help,
Adam
Posted: Sun Apr 18, 2010 11:54 am
by Paul
There are two types of resin, poly and vinylester. The later will not melt your foam. I did not mean to imply covering the entire thing, but just to use this in sanding down the high spots you make with the micro/whatever mixture. This is to avoid filling a low spot with micro and then creating other low spots around this hard spot when sanding. If my meanderings are still unclear give me a call: 303-903-1270. I'll be out changing the brakes on my truck.
Paul the Denverite
Posted: Mon May 24, 2010 7:32 pm
by amayotte
UPDATE
I just started to fiberglass the rudder today. I have put 5 layers on her and she seems fairly good but still a little squishy.
I was wondering if anyone could give me an idea as to how many layers a person should put on or just keep going until it's solid?
I was also wondering if someone new of a good marine paint I could put on the rudder or something that might mix well with epoxy resin.
Adam
I will try and put up some more photos tomorrow.
Posted: Mon May 24, 2010 8:52 pm
by Paul
At 5 layers (not sure what weight glass you are using) you should be pretty solid. I'm assuming you are using glass mat and it's all the same direction. Make sure you put a couple layers on the bias (45 degree angle). That makes a huge difference. You can also make a temp/portable oven and bake it to around 400 degrees. That changes the structure of the resin. Just set it on a piece of aluminum foil, shiny side up. Cover with clear plastic 3 mil or thicker and let the sun do its work.
Posted: Tue May 25, 2010 5:25 am
I like the baking tip!
Simple and elegant! Now if onl;y we had some sun in Seattle!
Posted: Tue May 25, 2010 7:40 am
by amayotte
Awesome tips Paul. I am going to try them.
However the weather just dropped to a beautiful 4 deg C with the occasional snowfall mixed with freezing rain so I am probably going to have to wait a week or so for some nice sun.
I just love northern Canada sometimes.
Adam
Posted: Tue May 25, 2010 8:00 am
by amayotte
Would it help too if I put on a layer of thickened epoxy with 404 filler once all the layers are on?
Posted: Tue May 25, 2010 5:00 pm
by Paul
The epoxy has no strength of its own. You would just create a brittle surface prone to cracking if hit by anything. It's the combination of glass and resin that creates the strength... like agregate in concrete. If you want to create hard points to fasten things to or protect the surface you can add to the resin: microballoons (discussed before) to build up an easly sandable surface or cotton flocking which makes the cured resin very hard. We used it for making wingtips and other parts prone to impact.
Best to you
Posted: Tue May 25, 2010 7:11 pm
by amayotte
Thanks again Paul for the wisdom...much appreciated.
Here are some photos of the glassing. I still have lots of work to do but it is slowly making it's way.
It kinda got a little messy once I tried doing some at a 45 deg angle. I will have to sand out some of the strands that dragged down.
And for those who are wondering the black marks are from my marker where I marked the cut lines.
Send some more next week.
Adam
UPDATE...ready for paint
Posted: Sun Jun 20, 2010 3:54 pm
by amayotte
Here is the finished glassed foil. I think I am going to leave her in this state and get the boat in the water and next year paint her.
Oh ya, I thought I might as well post this while I'm logged in.
I pulled the old keel winch which turned out to be a Fulton 945.
I replaced it with a Fulton 1550.
I have to replace the cable now because it was like handling a rose stem with all the wires sticking out. Lots of band-aids when I was done.
Futon 1550
Posted: Mon Jun 21, 2010 5:30 am
by hp18carr
Adam
Nice work on your rudder... I for one would lack the nerve for such an extended project, but to my question at hand. Changing from the Fulton 945 to the Fulton 1550... did you find you needed to make any modifications to get it to fit properly? As you can see I'm due for a change.
Chrysler 26 1980
Posted: Mon Jun 21, 2010 6:26 am
by amayotte
no, the only change was to the wood. I needed to make one hole larger and one hole on the other board to accomadate a new bolt in the winch. Very easy. You won't have any issues.
I think the two winches are the same size.
Posted: Mon Jun 21, 2010 7:17 pm
by amayotte
Another update...
Here are some more pictures of how the new rudder post, tube, and bushing all fit together.
First the post attaches to the rudder
Then the rudder post and bushing are placed into the tube. This tube is a FRP tube that I glassed into place last summer. (still haven't finished the final glass touch ups)
Once the post is in place the upper bushing, lock collar and tiller attachment are put into place.
(I still have to cut off the excess rudder tube.)
This setup is extremely smooth and tight. I am very happy with and glad that I spent the time to do this...very excited.
