I thought I was ready to launch
Posted: Sun Mar 21, 2010 8:49 am
by SN691
Posted: Sun Mar 21, 2010 9:20 am
by Bhacurly
Bummer Bob!
Same thing happened to my Buddy. His may have been due to letting the motor sit all winter without draining the carb. Mine sat all winter too, but was a new motor last year and I think I got lucky, but I did change the fuel filter and oil filter last week and use Sea Foam in my gas...
I plan on being more proactive this year when putting it away in the Fall.
Hope your on the water sailing soon!
Billy
Posted: Sun Mar 21, 2010 10:58 am
by SN691
I did run all the gas ou of the carb in Nov 0f 08 and drained all the gas of the tank so it was fresh gas
Posted: Sun Mar 21, 2010 1:09 pm
Posted: Sun Mar 21, 2010 1:59 pm
by SN691
I checked the spark plugs, thay were good. The gas was new just bought it three day a go. Fuel filter clean and the fuel line was ok.
Posted: Sun Mar 21, 2010 3:20 pm
Hmm, sounds like you checked everything I would have checked. I'm thinking too much or too little fuel. Oh, or maybe a head gasket. I had this issue with my last motor. The head gasket between the two cylinders was breached but the outer seal was okay so I would get a good compression on either cylinder but I could not do anything but ideal. As soon as I would rev it up it would die. It also ran hot even though the water pump was fine.
Do you have any grey/brown foamy, greasy, goop coming out the exhaust area of your motor. My exhaust would be out the center of the prop. This would indicate a blown head too.
I ended up buying another used motor as the parts were impossible to find for that old Suzuki. Love the new, used motor I got, it's been a champ, starting on first or second pull every time.
Hope they fix for you soon so you can get back out and sail!
Posted: Sun Mar 21, 2010 5:25 pm
Bob, the latest pics of the interior are incredible - stern berth looks better than I've ever seen.
How are the lake levels for you now ? Was looking back over the old posts of the problems out there.
Oh, "retired-occupation-wise", you might be interested to note that I'm writing from a former conducter's house, about 100 yards from the switch yard of the old Illinois Central in SW MS....
Posted: Sun Mar 21, 2010 5:26 pm
by Mario G
I'm going to say Alan is right about the choke sticking , I would say the carberator needs to be cleaned..I'm sure its the same thing with my 9.9.
$170 hr sounds crazy or I'm in the wrong job
sorry it didn't work out we will try to keep you entertained for another week :D
I to would rather be sailing
_C-26 Shaken Knot Stir'd
C-22 Don't Wake Me
Posted: Mon Mar 22, 2010 5:26 am
by al the pal
Posted: Mon Mar 22, 2010 8:49 am
by Capt. Bondo
Sometime all you need to do is turn the carb adjustment screws in and then back out to there origional settings. Just some dried gunk from the winter.
Posted: Mon Mar 22, 2010 9:02 am
by SN691
EE . In the stern berth the wood is from an old 13 foot market umbrella that the canvas was all torn. The small wood strips are Brazilian hard wood that I cut to size and then varnished and installed over the carpet.
Al the pal. After we removed all the old foam back liner in both stern and v-berth and in the cabin. Then we painted every thing and added a gray marine carpet. Then we put a burber marine carpet on the floor, All the cushions were put in by the original owner with four inch foam. We started in fall of 2008 but in December of 08 I had prostate cancer so that put a stop on things until late spring of 09. Then hot summer made it to hot to work in side the boat. In the fall of 09 we did a lot of work then winter came along and to cold for the glue to dry. In the first of March it got warm enough to finish.
Posted: Mon Mar 22, 2010 9:09 am
by SN691
I bought the motor new in Aug. of 08 and I checked and it has a three year warrany on it. So I may come out smelling lake a rose :wink: :wink:
Posted: Mon Mar 22, 2010 1:40 pm
Posted: Tue Mar 23, 2010 5:53 am
by NYCSAILOR
that is what is going on, that is why it is starting to pay to purchase new OB's and not bother to fix teh old .. parts are expensive too. in my area the guy is selling brand new 4-stroke suzuki 9.9 for 1,850. we are becoming a more disposable society than ever!
Posted: Mon Mar 29, 2010 10:07 am
by SN691
Posted: Mon Mar 29, 2010 12:49 pm
Posted: Tue Mar 30, 2010 2:47 am
Bob, how's the water level and the marina issues fairing for you guys out there ?
viewtopic.php?t=913&highlight=
viewtopic.php?t=1184&highlight=
Posted: Tue Mar 30, 2010 7:58 am
by SN691
EE
We are still in a drought the lake is coming up some, All the ramps are open now. The lake is 156 feet from the top as of today. The experts are guessing it will be about 80 feet down from the top before it starts droping in early summer. Ther farmers in the valley gets most of the water and they are only going to get about 60% of the water they need. so produce from Califorina will be high this summer.
As for the marina Forever Resorts got the contract from the State to run the marina for the next 30 years. They bought all the equment from the old operator. So every thing worked of fine at the marina. Now all we need is for the new operator to do the repairs that the old operator never did.
Posted: Tue Mar 30, 2010 4:55 pm
by Mario G
Got to tear down the carberator on my Evinrude 9.9 today and clean it.
I think it took about an hour in total. I'll see tomorrow how it all works out.
