How do you install these
Posted: Wed Feb 24, 2010 10:46 pm
by snowbordlb
How do you install one of these? Do I have to replace the entire cable?
http://www.westmarine.com/webapp/wcs/st ... /0/0?N=377 710&Ne=0&Ntt=stay&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=stay&isLTokenURL=true&storeNum=130&subdeptNum=10902&classNum=10902
Posted: Thu Feb 25, 2010 6:34 am
Before running out and buying that, check you boat.
The aft stay on the C22's is split. There should be an aft stay adjuster there already. Maybe it is missing? Maybe it is free floating and not hooked up properly?
Here is a picture of it. Hard to see but it is there top left of the photo!
This photos was shamelessly linked to at chryslersailing .com
Posted: Thu Feb 25, 2010 8:11 am
by snowbordlb
I have one but it is worn out. The adjuster is smoth so it is hard to turn i guess once i get it set i can just leave it but i figured for $39 it might be nice to have a new one. I was looking online and it says something about swage connections. I dont know if you need a special tool for that or not
Posted: Thu Feb 25, 2010 8:21 am
by somers12
swaging involves a 40 ton press with the correct dies, and is best left to a professional rigger.
Steve
Posted: Thu Feb 25, 2010 8:25 am
by John K
Steve, your statement conflicts with what you signature line says. j/k
Posted: Thu Feb 25, 2010 8:52 am
by J. Austin
Ha funny,
I noticed that too.
In Steve's defence, a press is kind of a really large, slow hammer.
Posted: Thu Feb 25, 2010 11:39 am
You can get a swagless fitting such as a sta-loc to attach it.
Posted: Thu Feb 25, 2010 12:16 pm
by snowbordlb
Cool. I am going to San Antonio this week so i will check out westmarine. I think i might just try to replace the adjustment screw.
Posted: Fri Feb 26, 2010 9:46 am
by Capt. Bondo
I don't think C22 came equiped with back stay adjuster standard.
Mine does not have one and does not appear one was ever installed, no holes.
I'm thinking of installing one of these split adjusters
http://www.defender.com/category.jsp?pa ... &id=298804
Posted: Fri Feb 26, 2010 10:21 am
Depends on how you define "adjustable".
