soft spot repair
Posted: Fri Jan 29, 2010 2:28 pm
by STEVE ROYER
does anyone know of a way to repair a soft spot without cutting it out
soft spot
Posted: Fri Jan 29, 2010 2:59 pm
by hp18carr
Do a forum search on soft spot on deck you will find advice there.
Chrysler 26 1980
Posted: Fri Jan 29, 2010 3:36 pm
If the core is dry, you can inject the area however I've never done this myself so one of the more knowledgeable folks will likley chime in.
Posted: Fri Jan 29, 2010 4:10 pm
by Gus
How big is it? One way is drilling holes and let it air dry, then inject epoxy resin. I had a couple of soft spots (more like 8) and I had to cut the interior liner and replace the rotten plywood. If I have to do it again, I would cut the exterior skin instead.
Posted: Fri Jan 29, 2010 4:44 pm
Hi Steve. L-o-v-e-l-y weather we're having isn't it !
