It seems the po extended the cockpit locker and enclosed it with untreated painted plywood. You will not the fitting top left is the bilge exit point, all the bilge water directly into the transom... not good the way I see it. Hopefully all the rotten wood is centered close to the locker extension.
I ripped out all the old carpet in the cockpit locker, just more prep work for my growing list of summer 2010 projects
Chrysler 26 1980
Overhaul... transom trouble
I was just wondering about that plywood just today. I was hoping to attach an AC breaker box to it since that will be close to where the shore power is going to come in (current plan)... but it does look suspect.
Thanks for posting this!
1979 C-26
My bilge pump comes out above sink drain behind bulkhead Just below toe rail. work done by orig. owner
Yes Terrence Get it outside the hull. A through hull would look good that is what I have.
