wheel steering
Posted: Wed Sep 30, 2009 5:04 pm
by javelin
I have seen some 26ers with wheel steering but none with an outboard. Question: if I should get wheel steering, do I have to give up my outboard ? The reason I ask is many of our yacht club members wait weeks and weeks for parts for their inboards, while if I have a mechanical problem, I just take the Mercury Outboard to the dealer. Also does anyone know a source for used wheel steering systems and are they impossibly difficult for the novice to install ? Russell on Javelin
Posted: Thu Oct 01, 2009 6:10 am
by Windward
Russell,
No problem using an outboard with wheel steering. If a local guy and NYCSailor both decide against it, I'll drop you a line. I'll be gone sailing (and getting back and forth, etc) Oct 8-26, so likely after that.
Installation shouldn't be that tough, based on how easy it was to remove. There are some Edson directions available for download somewhere, IIRC.
Posted: Thu Oct 01, 2009 7:10 pm
by lecker68
Yes you can get the wheel system from Edson marine
http://www.edsonmarine.com I have one on my 1980 C-26
Posted: Fri Oct 02, 2009 1:15 pm
by sailbob
"CRYSTA" Has an Edson steering system and a 9.9 HP Bigfoot Mercury outboard. They work well together and I am extremley pleased with the set-up. System is cable running through pulleys to a steering quadrant attached to the rudder post. Looks pretty simple to install if you have instructions.
Posted: Sun Oct 04, 2009 4:20 am
by javelin
thanks for the advice, guys. I talked to edson and they have a specifc system for the 26 for about $2600 US.
Posted: Mon Oct 05, 2009 8:00 am
by NYCSAILOR
jeff,
pm sent...
