Located on the front edge of the rudder housing it is approx. 7 1/2' long and has four screw holes, two on each side.
Email : ssouter63@att.net
Phone 972.406.1033
Wanted: face plate for C-22 rudder assembly
Steve,
The original's a plastic fairing. I just made a fairing block from wood, then coated it with epoxy. You could probably use thin wall aluminum tubing, too. Of course, you might get lucky and find someone with an extra...
