WOW!,
I jsut started doing thsi.... my hatchboards were really scary.., I sanded, and sanded and sanded and then used the Sikkens Cetol Teak product... 4 coats.. really liked it so far.... great result... also dismantled the companionway ladder sanded and sanded and then the cetol... 3 coats... looked good..... nxt will be the slats before the companionway and then removal of the sliding hatch... fresh teflon tape and refinish the teak there with Cetol as well..... bought a new tiller and will finsih with bristol but it is about 1/2 or less thinner stock for the tiller post bracket so I will have to put in some aluminum spacer or something there..
also my curtains were scary (OEM).... made my boat look like a ghost ship from outside and worse inside... So I am removing the curtains ( they literally need to be ripped off as they were pop-riveted into the liner!) and tinting the windows for a more modern look but I think all new windows are in the cards..... hoping these might ft.....
http://www.cruisingconcepts.com/retroftwin.htm
anyone know what exactly from the catalina's will work on the chryslers?
thye have lots of vendor and aftermarket support and some of the stuf looks generic enough..
BTW: I was amazed to see that you have the EXACT same knotmeter as I do in the exact same location... my is dead.. does yours work? Where did you get parts?
