keel slapping around....
Posted: Sat Jul 18, 2009 1:47 pm
by tnc110
so it got my c22 back in the water today...and i noticed a thumping sound. turns out its the keel sliding side to side on the pin...anyone else have this problem?
Posted: Sat Jul 18, 2009 2:22 pm
I shimmed mine with washers when I reinstalled it, even so it still thumps if the waves are large enough as the cable looses tension.
Posted: Sun Jul 19, 2009 1:36 am
by Chrysler20%26
tnc, Good to see you back in the water, if your girlfrend is sailing with you, I would say she's a keeper. Better luck sailing.
Posted: Sun Jul 19, 2009 11:31 am
Posted: Sun Jul 19, 2009 1:53 pm
by parared
Hmm, I've heard this before, but thought it was a back and forth thump, ie the bow raises on a wave, swing keep swings a little aft, then bow comes down, keel goes forward and thump.
My boat had the keep pin totally redone just before I bought it ( saw the receipts from a good local marina ), so I *hope* its not going side to side. On mine, it was definitely correlated with the bow coming down after a good lift.
Don't some swing keels seem to have a mechanism to lock the keel down?
Posted: Sun Jul 19, 2009 2:39 pm
by tnc110
i did some investigating today... when i re installed my new keel i glassed over the large hole above/aft of the pin that the nylon rod came through. i did this because on the inside at the area that the flange mounted to was rotten. it was bad enough that i know that it would never have sealed back up. i assumed that this nylon pin was designed to lock the keel down so i didnt think that i would need it. however i think that maybe the nylon rod is used to push on the side of the keel to take up any slack??? my original keel never made a noise when the nylon rod was in place...
today i cut an 8 inch circle out of a 1/2" thick nylon sheet. then drilled a 5/8 hole in the center. cut a 5/8" slot from the edge to the center hole, leaving just enough material around the hole so that i can smack it with a hammer and get it to "click" onto the keel pin. was planning on using this as a shim to get the keel to tighten up a bit, but the 1/2" shim was too much/too thick. tomorrow i'm gonna try to find some thinner material and try again...
Posted: Mon Jul 20, 2009 10:26 am
by Gus
Yup, that's what the nylon pin its for, it was there for a reason to start with.
Posted: Mon Jul 20, 2009 1:04 pm
Yeah mine was really corroded to almost nothing and did not work so I just removed it, it really is only a issue in really large waves and even then I crank it up a little more to put more tension on the cable.
