main sheet bridle
Posted: Thu May 28, 2009 6:42 pm
by gregg
does anyone know what is in the main sheet bridle mount on the stock C-26 is inside that hold the blocks down.I made custom risers for a traveler and two screws on one side and one on the other are stripped. I would like to just retap them to 1/4-20 if its a plate I just painted the inside ceiling would hate to cut it all out
Thanks Gregg
Posted: Fri May 29, 2009 8:57 am
Not sure myself - I'll take a look at EE's tomorrow and let you know !
Posted: Fri May 29, 2009 9:07 am
by kokezaru
Hey Gregg, I think it is just a piece of wood, like the mast step. Was there any residue on the screw threads that could give you an indication?
Also, I just got a piece of track for my C26, and I was trying to decide on what to use for a riser, what did you use, and do you have any pics?
I am planning on bolting all the way through and using a backing plate on the cabin ceiling, I figure that anything that can be beefed up, should be.
--Richard
Posted: Fri May 29, 2009 4:03 pm
by gregg
I do have some photos of them I'll try to post tomorrow. the screws that mounted the blocks on are 10-24, four on each side I'm afraid that they are wood nuts with the little grippers to grab the wood and three are just spinning
Posted: Sun May 31, 2009 7:15 am
Didn't get a chance to see mine yesterday, I'll check on it for you Wednesday.
Posted: Sun May 31, 2009 10:25 am
by gregg
any help would be great!
I was thinking to use some long wood screws to help it out also if ist's wood in there
Posted: Sun May 31, 2009 12:21 pm
I'm pretty sure mine is same as SailMonkey's reply in the For Sale Section - thrubolted. But I'll verify that whe I get over to the boat.
