Outboard Motor Bracket
Posted: Wed Apr 22, 2009 3:58 pm
by skyking
I need to find a outboard bracket for my C 22, is there any certain one that i should look for? Also What is the correct location that it should be mounted on the transom?
I have seen them in various locations?
Posted: Wed Apr 22, 2009 5:54 pm
by Andiron120
Garelick makes some good ones, just have to pick on that is appropriate to the motor you are going to use. My motor is centered and locked down, all steering is done with the rudder. Electric start and controls run just outside the companionway. You do have to keep in mind that he rudder might get into the prop if it kicks up though. Also have to check and make sure there is enough backing in the transom for the mount. I am sure there are some other good solutions also.
