Opinions? Keel pendant-stainless cable or synthetic?
Post All Keel Topics Here
gregcrawford
Post by gregcrawford »
In cruising the net, I have seen both stainless cable and things like low stretch vectran synthetic used for the keel pendant. What do you use, what diameter is it, and how much do I need?
Mine is, unfortunately, galvanized and kinked.
Greg Crawford
Knoxville, TN
1976 Chrysler 22 "Blues Image"
Stainless steel and 3/16", the last owner installed it.
Chrysler20%26
Kell cable
Post by Chrysler20%26 »
For fresh water sailers, I think Galvanized cable, would be better than Stainless. Need help on this post, What is the best????
I vote stainless and I sail salt!
Hmm, does that make me a salty sailor??
Stainless 3/16".
Gus
Post by Gus »
Don't go with the rope, use SS wire.
gregcrawford
Thanks, everyone.
Does anyone remember how long the cable should be? If not, I can unspool it and measure it.
Greg Crawford
Knoxville, TN
Windward
Post by Windward »
On Windward (C26, not C22) I upsized to 1/4", and am using stainless cable. Believe length there was 9'.
Sadly, none besides the "stainless" is likely to help you much.
Sailfrog
Post by Sailfrog »
Chrysler22%26,
Why do you think galvanized would be better for us freshwater sailors?
Great Lakes sailor
Chrysler20%26
sailfrog, I have only ben sailing four 3 years. But I was an Iron Worker for 33 years. Stainless cable does not like to bend, an likes a stedy pull. Our swing keels bounce around a lot in ruff water. Galvanized cable is stronger, more flexable, an will with stand the keel bouncing up an down. I have Galvanized cable on my C-20 an on my Mac 25 . The cable is vary old, an has no broken strans. My C-26 Has a rather new Stainless cable, with a lot of broken strans. I have both types of cable on stand by. 3/16 9' I keep the keel up all the time. Just don't trust the cable, I never got around to chang it, an now the water is to cold. I am sailing every day I can, but times running out.
Now that is good info from a view of experience !
Sailfrog
Post by Sailfrog »
Thanks for the informative answer Chrysler20%26. I'm south of you, in Plymouth, MI and I agree, the water is getting cold. But, that's why they make wetsuits. My boat sits on the trailer unless she's sailing so corrosion won't be a problem. But, I'm grateful for the knowledge about the differences between SS and galvanized. Makes sense to me. Actually, based on your information, I think I might go with galvanized even if I sailed salt water.
