The boat looks to be in good shape, and the resources available on the web, like this one, helped me choose the C22.
It has no motor. Do I need a long shaft, it looks like the motor mount goes pretty close to the water?
Thanks in advance for any help!
Gary
new C22 owner Madison, WI-help with choosing motor
The type of motor you need depends on the conditions where you are sailing.
Last season my outboard only ran on one out of two cylinders, I only had problem motoring against strong winds and waves.
I am sailing in Norway and definetly needs a extra long shaft. I have a 9.9 johnson sailmaster.
One problem with the hull is that the aft will go lower in water as you start to speed up. This calls for a long shaft.
I have raised the motor mount on my boat last year after flooding the engine due to high waves.
