C-26 Roller Furling Survey
hotdot
Post by hotdot »
This summers sailing adventure was the last I will have with a reliable crew and I am going to have to install roller furling for my jib. I have read all of the product brochures and info, studied furler installation on other boats but am wondering what type of furling system my fellow C-26 sailors are using. I am currently leaning towards a Flexible furler because of the self contained halyard and flexible plastic extrusion. I am not convinced that the Flex-Furlers are strong enough or built to last. I would appreciate any comments you have regarding furlers on your boats and what size jib your using.
STEVE ROYER
Post by STEVE ROYER »
That's what I have on MOON SHADOW an FF6 it's not as fragile as the alum extrusions and it's all pvc means no crosion to deal with
NoRush
Post by NoRush »
I am using a similar set flexible furler with contained halyard. Flying a 140 genoa but have also used a 110 on the same system.
I have had no issues other than expected furling line replacement, I wouldn't be without a roller furler on a cruising boat.
skyking
Post by skyking »
STEVE ROYER wrote:That's what I have on MOON SHADOW an FF6 it's not as fragile as the alum extrusions and it's all pvc means no crosion to deal with
Who has these extrusions? I have a roller furling that I would consider using if I could locate the extrusions?
amayotte
Post by amayotte »
I have a PROFURL LC32 and it works great. It's never gotten stuck or bunched up on me.
It has an open bail which I think is a definite, in case your rope does turn into a rats nest.
My two cents,
Adam
skyking
Post by skyking »
This is the roller furling that came with my c-22. Can someone help identify it? Is it possible that it was original chrysler equipment?
http://i958.photobucket.com/albums/ae61 ... 0_0860.jpg
http://i958.photobucket.com/albums/ae61 ... 0_0861.jpg
http://i958.photobucket.com/albums/ae61 ... 0_0862.jpg
dennyzen
roller furler
Post by dennyzen »
This is my number one WANT. And while I have the mast down, this will be the most expensive thing I've ever gotten or ever will get for the boat, I thinks.
It is the one thing that would allow me to single handle more often.
Please post 'em.
1979 Chrysler 22--flatwater sailing on Lake Jacomo
skyking
Re: roller furler
Post by skyking »
Here are the pictures again, I assume that you are not able to use my links?
dennyzen wrote:This is my number one WANT. And while I have the mast down, this will be the most expensive thing I've ever gotten or ever will get for the boat, I thinks.
Please post 'em.
hotdot
Post by hotdot »
Thanks for all of the replies. I decided to go with a Hood SeaFlex. Defender had the best price and Sailrite had jib conversion kits so I could sew the luff tape myself. Overall I'm very happy with it. I have a Sta-Loc fitting on my forestay and the drum of the SeaFlex fit over it nicely with no issues. I prepared myself ahead of time to deal with possible halyard wrap so referencing an old "Things That Work" textbook by Sail Mag I placed a small piece of pvc tubing around the portion of the jib halyard that extended from the masthead to the furler swivel (about 4-5 inches). This kept the wire from being able to wrap and jam up the furling action. When I take the mast down for the season I will install a proper halyard restrainer. Just as a matter of note, my total cost for the furler and jib conversion set me back about 500 and after sailing with it for a weekend it was worth every penny! No more hank-on sails for me!
