Okay, this is what happened. Sailed over some unmarked rock, keel lifted and then slammed down, snapping the cable. Here is what I need to know: 1. the cable broke about a foot from the end of the winch---- can I rethread the remaining cable and reattach to the winch ( in other words, was the original cable long enough that I can afford to lose about a foot)? 2. If I have to replace the cable, how long is it and what gauge
3. The keel, when it slammed down, may be stuck. Is there a trick to freeing it ?
I am arranging for a haulout to do this work, hopefully tomorrow, Wednesday July 15
Any help REALLY appreciated. Russell
HELP CABLE BROKE FROM KEEL
I'd replace it. It may have been overstressed somewhere else as well. If doing it on the hard you'll need about the bottom of the keel pocket to be between 30 and 36" from the ground.
As far as getting the kell raised see a topic on Jeff's site is here:
http://chryslersailing.lizards.net/sail_swingkeel.html
My nasty pics are here for a look at how much clearance you need.
http://my.att.net/p/s/community.dll?ep= ... 305424&ck=
If you search the forum for "keel" and "cable" ( and choose the "search for all terms") option you'll find a few threads on replacing it in the water.
