Chrysler 22 Keel Cable
DejaVu
Post by DejaVu »
I purchased a Chrysler 22 last summer. We had a great time on her . My biggest concern is that the Keel Winch Cable is a Nylon line. I’m not feeling warm and fuzzy with this set-up.
Do you think that I should change it out to a cable? If so, does anyone know the correct size? 3/16” or 1/4”?
Re: Chrysler 22 Keel Cable
The swing keel weighs over 900 lbs. Stainless Steel 3/16" wire rope is the only option. REPLACE it and all supporting hardware at your earliest convenience , or when it (nylon) breaks, the keel trunk will get damaged when the keel falls and find yourself unable to easily retrieve
DejaVu
Post by DejaVu »
I’m definitely going to do it before spring launch. Have you done it on the trailer? I can clearly reach the shackle.
