Anchors Away
Anchors Away
If you're using your V-birth for sleeping where do you stow your anchor chain and row for easiest access on a 26 Chrysler?
Re: Anchors Away
I have mine right behind the companion way entrance. I do not use my aft section for sleeping, and there is a shallow holding area on mine with a board that covers it.jfishburne wrote:If you're using your V-birth for sleeping where do you stow your anchor chain and row for easiest access on a 26 Chrysler?
Re: Anchors Away
Thanks for your suggestion. I use my aft section sometimes for sleeping and since I drop my primary anchor from the bow, I'm hoping to find a way to keep the chain and rode near the bow. It's heavy and I'm not as young as I use to be ;0)
