C 22 Rudder Issue
billsfan60
C 22 Rudder Issue
Post by billsfan60 »
Ever since getting off the beach last fall with our C22 I've been puzzled about why the rudder won't clear the bottom of the motor no matter what position the outboard is in. It clears just fine in all but the horizontal. Am I missing something here???
C26 is same way. You can run loop of line from the tiller to a block on each corner of the stern then to the rear of the outboard so that it turns with the rudder when in up position..
astrorad
Post by astrorad »
excellent tip EE
billsfan60
thanks guys, will give it a try.
