I plan to have a 12V system as well as two 110V systems. One 110v system will be from a shore line and one from an on-board inverter.
The 12v system will consist of two group 24 batteries connected to a batt1/batt2 switch so I can run them in parallel or separate. I plan to have a decent sized 12v switch/breaker panel and would like to mount it just inside the companionway on the port side. I would like to build a box in the area that is curently just a shelf and create a hinged drop down panel. I'd like to be able to reach the panel from the cockpit by just leaning inside while still standing in the cockpit. I though about installing all the switches in a panel created into the shelf above the table to create a bit of a "nav station" effect. Although cool looking I didn't want to climb completely inside the boat to turn anything on or off. The original location of the switch panel seems pretty silly to me.
The first two thing on my agenda are to determine the location of the batteries and the shore power inlet plug. I'm open to suggestions for each. I'd like to keep the batteries next to each other and close to the centerline of the boat. Those two requirements seem to be making my options slim. I could potentially put them directly under the cockpit floor as far forward as possible, but accesability would be difficult plus I'm unsure about drilling in that area. Is there room before going through the bottom of the boat, and if so would I have access to thru bolt?
Suggestions on where to put my shore power plug? I have this pretty little item...
http://www.westmarine.com/webapp/wcs/st ... sNum=50526
Anyway, I plan to keep this thread updated with my progress. In the meantime It's going to start getting cold out and I don't have the comforts of a large garage to work in so I've decided to create a tent over the boat so I have a little shelter to work in and can run my torpedo heater in to hopefully make working conditions bearable. I will also be rebedding all the deck hardware as there are tons of leaks so with some shelter I can take my time and on occasion leave some of the holes open for a day or so until I come back to it.
First few steps in creating my tent....the frame work....
[/URL]
