Starboard ThruHull C22
Hi,
I just picked up a '76 C22 and noticed about a 1" or less hole about mid cabin below the water line which appears to be purposely made? There is no thru hull fitting in place so I am wondering if I am missing something or just need to plug it.
Thanks, DVD Sarasota FL
Welcome to the forum DVD!
Glad to have ya!
The starboard through hull on a C22 is factory. Your C22 originally came with a small slide out stove and sink. This was normally stored on the starboard side in the lazerette however slide forward on a track into the cabin on the starboard side. The sink would drain into a little hole in the sette under the cushions which would then drain via a hose into the little storage cuby under the cushions, starbord side just aft of the bulkhead. That inturn drained through the through hull!
Hope this helps!
Glad to have ya!
Hope this helps!
- Chrysler20%26
Welcome to the "Family" DVD. If you search under C22 doccuments, zI scanned the install instructions for the galley. If you don't have the galley, you can always cap it inside.
Some people like the galley option, don't know that I would want to try to cook in such cramped spaces.
1979 C22 S/V Client Meeting
Welcome aboard ship mate.
Yup Captain Scot nailed it. it's a drain for the sink and yes it should be closed when sailing. There should be a stop cock on the through hole on the inside. The original Chrysler doc's said to always close the sink sea cock when not in use and to never use it when under way.
So you got a 1976 C22. It was a good year, a fine vintage I must say, my personal favorite. Oh did I mention mine is a C22 as well.
- gregcrawford
I took the plastic through hull out of my 1976 C22 and replaced it with an honest-to-goodness bronze through bolted seacock. I epoxied a teak pad to the hull, drilled three holes through the hull and installed countersunk screws bedded in 3M 4200. I know, I know, good practice dictates two clamps on each fitting. This picture was taken before I installed the second clamp on everything that would accept two clamps. I now have to install a tee and a second shut off valve so that the galley can drain via this outlet. The hole in the bulkhead on the left side of the picture is where the galley drain hose normally protrudes. This seacock is kept closed at all times unless I am using the washdown pump. The washdown pump works great as I have no water supply at my dock. I use it to wash the boat several times each summer. Plus, if you get close enough you can spray people on the shore or other boats...
