One of my projects this fall for WindWalker to lead the halyards back to the cockpit. Since the jib halyard is too short to my liking, both the main and jib halyard could be extended several feet and both are the same length, I thought I might as well replace the wire halyards and lengthen them while I have the mast down.
Looking for replacement wire halyards I came across the wire to role spliced aftermarket which looked interesting but would require me to crimp the eye into the wire and would not be as long as they could be (I figured 31' since the I measurement for a C26 is 31.5', 6 inches for the masthead sheaves and eye splice and turning blocks at the base, what can I say, I'm a perfectionist). This is one option.
The second option I came across is Samson Ropes Amsteel blue with a average strength of 2500 lbs in 1/8" diameter, AND it comes in colors! I can splice the eye into the rope myself and have it any length I want. This rope has GREATER strength than a 7X19 SS wire rope the same diameter , AND will fit the masthead sheaves.
Has anyone done this replacement? Any feedback, thoughts, heckles?
And yes, I'll mount the Windex when the mast is down.
Amsteel for wire rope halyards?
- Windwalker
Dave
1976 Mutineer
1976 Mutineer
- Windwalker
Nope. It may be overkill, 1/8" 7X19 SS breaking load = 1600 lbs, 1/8" Amsteel average strength = 2500 lbs (4000 lbs for 5/32), but I can splice it myself, I can splice it to a 3/8" double braid (http://www.l-36.com/halyard_splice.php) to run through the rope clutch, it will fit in the sheaves, AND it's cheaper then steel.
I am asking for anyone to share their experiences with Dyneema line and try and talk me out of it. Not that I want them to, but it almost seams too good.
Dave
1976 Mutineer
1976 Mutineer
jerecaustin.com
jerecaustin.com
- Windwalker
