Toe rail where can it be bought?
I'm missing about a 6' portion of port side toe rail. Is it possible to find replacement?
You can but everything I have seen has a slightly different profile and mounts from the top instead of the side. None of them have the bumper built in either. Here is one of the suppliers I found.
http://www.crestaluminum.com/Main/Marine/Toerail.htm
- clair hofmann
There was someone on the forum that was considering buying a 22 to part out. I don't remember who. I looked for the post but couldn't find it. I need a section for my 26 and did just that. when Moonshine Jim was parting out his 22 I went and got his port toerail. I'll figure out the best place to make the splice then cut and tig the two together.
It helped that he was only 20 miles from me and I was able to go pick it up. If you only need 6', that could be cut and sent UPS.
Clair
Clair
- clair hofmann
